Hello,
so after X years I finished my first milling machine.
The goal was to build a small milling machine about the size of a Tormach Pcnc440 or similar, on ball bearings and as accurate as possible. So that I can move all the parts myself.
I don't have any workshop equipment (except a little old horizontal router that I just drilled holes on).
The base the column with the coupling of the column and the base consists of thick-walled steel 200x200x12. (All units in metric millimeters) The base and column are filled with concrete.
I decided to use ready-made new linear actuators from THK - KR46 instead of the classic solution of rails and screws due to the simplicity of construction and assembly
in precision class P, which are preloaded in the line and the ballscrews have a maximum backlash of 0.003mm. THK declares high rigidity, but this has turned out to be a weak point, but too late.
Departures:
X - 380mm (only 300 are usable due to the planned fourth axis)
Y - 145mm
From - 310mm
Spindle: 1.5kW Chinese driver 12000 rpm 2.3Nm ER20
The headstock is made of one piece.
Engines and drivers:
Vexta PK566 5-phase stepping motors with gearboxes 4Nm, 6Nm and for Z 8Nm. - the engines had to be stronger due to the 20mm pitch of the ballscrews.
UDK5114N drivers
Table - steel 540x150x40mm, grounded
Total weight: a little over 300kg.
In total, I had only 7 parts made. All mounting surfaces are ground so that I don't have a problem with assembly with precision.
Nevertheless, after setting X and Y, I measured with a watch the parallelism of the table surface with Y displacement, and the table flew down the hill 0.05mm...
So I covered the couplings between X and Y with aluminum foil and it runs at a hundred of mm. Fortunately, the table was straight in the X direction, so the whole machine runs without drag up to 0.012mm.
Another problem was the imprecise manufacture of the headstock - the parallelism of the bearing surface to the Z axis and the axis of the opening for the spindle.
It also had to be lined with aluminum foil when adjusting the verticality of the spindle.
I tried to make the first shots in structural steel.
I thought that the weakest link would be the spindle, but that is not the case.
The limit for a milling cutter is a slot of 12 mm 2flute carbide milling cutter in a depth of 1 mm, with 9000 revolutions and a feed of 140 mm/min, when the surface is still nice and the cut is precise.
The milled surface with several rows of such cuts was very nice.
The 6mm carbide cutter goes in a depth of 2 mm at 9000 revolutions with 140 mm/min feed, and 12000 with 200 mm/min feed completely smoothly and beautifully.
The machine is intended for aluminum and non-ferrous metals, approx. hard wood. Steel only exceptionally, so I do not lose heart because of this limit.
With a milling cutter of 12 mm and a depth of cut of 2 mm, it vibrated and the cut was already imperfect. The weak point, in my opinion, is precisely the actuators, which do compensate
or the used 15mm pre-tensioned rails, but I think that THK is lying a bit about their stiffness and max. Retraction that is, they do not indicate the degree of their deformation for different types of retraction, only the maximum permissible values,
which the milling cutter does not even come close to reaching.
I don't have aluminum yet, but when I try, I'll let you know how it went.
I think that no one here has used THK KR actuators with this construction method. If someone decides, they are available on ebay, they are terribly expensive new, and only used ones in the highest
accuracy class P, the others are not good. The p-grade They are exactly suitable only for the construction of such small machines. If I had to decide again, I would go to the rails and screws.
And it has one more flaw: after switching off, the spindle slowly self-falls down. should have a counterweight.
