587,019 active members*
4,094 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Rapid Feedrate in Test Mode
Results 1 to 11 of 11
    Sep 2011
    104
    Hello Okuma guys,
    Does anyone have an idea if there's a parameter controlling the Feedrate limitation in Test Mode (the one you trigger it with the physical key on the control).
    Normally when you switch from Production Mode to Test Mode there is a limitation but I want to set it lower.
    Control is P200
    Any suggestions?
    Cheers!
    Jun 2015
    4156
    Re: Rapid Feedrate in Test Mode
    hy gunda if you reffer to dry run, please check
    ... other function \ unit amount in dry run
    ... other function \ dry run active in rapid feed
    Sep 2011
    104
    I am referring to the Test Mode (as called in the Okuma manuals) that allows for feeding while the door is open (with the safety button pressed of course) and it also decreases the rapid feedrate in comparison to the Production Mode.
    In the picture attached the current selection is the Test Mode
    Jun 2015
    4156
    hy gunda i am not sure, since i dont use test mode, but look at " servo sys para ", " manu rapid ... "
    please make backup 1st, not only photo, but backup file and test it 1st, because changing one of those parameters also changes other values, and there may be limitations depending on where the machine was located/shiped, and you may have a hard time restoring original values ... thus the menu seems editable, but is not as direct as other menus, and has its inner mind
    please double check, search those in manual, so to be sure / kindly
    Jan 2013
    474
    Quote Originally Posted by deadlykitten View Post
    I think you'll find set up 1 and 2 test mode feeds are plc controlled, legally with the door open the feedrate is limited to 2000mm per min or around 80" min. Spindle speed is reduced too.
    For bigger machines there is both set up 1 and 2 to allow a test cut by the operator, set up 1 to prove the program.
    Sep 2011
    104
    I don't see the Servo System parameters page in the list of parameters. Is it locked/hidden?
    Sep 2011
    104
    Quote Originally Posted by gunda View Post
    Machine is a Multus B200-W
    Jun 2015
    4156
    hy gunda
    for details, please check " RAPID FEEDRATE PARAMETER SETTING FUNCTION " inside special functions manual
    for menu hide/unhide, please check youtube chanel " Gosiger West Applications Tips ", video " Okuma Lathe Parameter setup " , time 2:00
    please remember to backup 1st your parameters
    most simply overide to 30-50%; ain't it enough ? kindly
    Mar 2009
    1982
    there should be three speed override knobs on the panel: Cutting feed rate and positioning feed rate. Positioning feed rate override is the one you need, I guess.
    Jan 2013
    474
    That is set up mode not dry run with machine lock, the rapid override switch and single block etc should still work as in MDI or auto.
    The idea is to test cut a component.
    Sep 2011
    104
    Quote Originally Posted by servtech View Post
    Thanks for the ideas, I'll test tomorrow and let you know
  1. Miniature Rotary encoders for Feedrate, Rapid, and spindle overrides
    By crasher455 in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-25-2021, 10:29 PM
  2. Max and Rapid Feedrate
    By Atomic_Sheep in forum Uncategorised CAM Discussion
    Last Post: 10-20-2016, 07:45 PM
  3. Replies: 38
    Last Post: 03-09-2015, 05:19 PM
  4. Feed problem in Rapid Mode
    By elab.ess in forum CNC Machine Related Electronics
    Last Post: 05-07-2014, 08:06 AM
  5. Rapid Traverse Feedrate Override
    By liudongxjtu in forum Fanuc
    Last Post: 08-05-2012, 12:50 PM
