588,687 active members*
6,142 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Dust shoe - requirements and features
View Poll Results: What are the most important features for a dust shoe?
Voters
3. You may not vote on this poll
  • Changeable brush
    1 33.33%
  • Fits more spindle sizes
    0 0%
  • Made of transparent material
    1 33.33%
  • Price
    0 0%
  • Size
    0 0%
  • Easy to install
    1 33.33%
    Apr 2023
    Lightbulb Dust shoe - requirements and features
    This may be a niche topic, but i would like your opnion anyway.
    I´m trying to figure out a printable solution for a dust shoe.
    I´m well aware that they exist on serveral websites, but i want your opinion on which requirements and features are important for a dust shoe.
    Mar 2008
    454
    Re: Dust shoe - requirements and features
    I gotta say, all of those aspects are important to me.
    I'm trying to find one right now for my 80mm spindle with a 2.5" shop-vac hose fitting.
    Most of what I have found on ebay are giant monstrosities you cannot see through and the ones that are clear, are way too tall and made to fit a specific CNC.
    The brushes block the view at point of cutting and the height is not adjustable... I'm skeptical it would even fit between the spindle and the Z-axis mounting plate.
    This might be fine for repetitious cutting where everything is at a standard height, but the vast majority of my jobs are 'one-offs' with many different length bits.
    Sometimes I deep cut wood 50mm, sometimes I cut only 0.5mm traces into copper for circuit boards.
    The spindle holder on mine leaves exactly 1.5" of the 80mm spindle available for clamping below the bracket.
    The bracket has a thickness of .5" around the spindle.
    The bottom of the collet holder is 1" below that... some of my cutting bits are only 10mm below the collet, others are 100mm.
    So what I would love to see is:
    A thin, strong clamp for the 80mm spindle roughly 1" of Z-height tall, no more than 1/4" thick to clear the inside Z-axis mounting plate.
    A connector for the 2.5" hose on that with maybe a 5deg-10deg tilt away from the spindle to clear the holding bracket... otherwise it can be vertical if offset maybe 1" (hose plug-in is smaller dia than hose dia, you know what i mean if u have a shop vac hose).
    Then for the bottom shoe....
    We dont need a giant oval thing covering the entire area that the spindle plus hose connector takes up.... just need something like a PVC tube around the spindle collet that allows the same airflow.
    Trick is to make the height adjustable, and to not restrict the airflow from the main 2.5"dia tube.
    I'm thinking it would be best to have changeable shoe adapters, but each shoe needs to slide up/down a lil bit... even 5-10mm would do the job.
    Actually now I am wondering if I can find an 80mm PVC Y-adapter that can slip over the spindle, I'll cut it down to meet the bottom of the collet, make an adapter for the 2.5" shop-vac hose... and just make a sliding sleeve to match the height of my current working bit. It unfortunately wont be transparent, but would be a better option than what I can currently find.
    Let me know if you want to make something like this, I'd love to help with prototyping... Ill bet I'm not the only one interested.
    Mar 2008
    454
    Actually after thinking about it more.... thats exactly what I want:
    A clear Y-Adapter with an 80mm through hole that can clamp at the top for a good grip on the spindle.
    The Y offshoot needs to connect at the very bottom for max airflow and fit a 2.5" shop-vac hose... and it needs to fit around the outside, not the inside of the shop-vac hose.
    The straight-through length needs to be 2.5" tall max, and have an adjustable outer sleeve fitting for extensions. Then a set of sleeves of different lengths with intervals of roughly 1/2" to a max of 3".
    I'd pay $60 for that without hesitation
    Maybe also offer a model that clamps on to an 80mm spindle, goes down 1.25", then flares out into a cone with a 100mm dia
    BTW I am running an HVAC 'squirrel cage' blower through an 'oneida dust deputy 2.5' collector
    Feb 2005
    117
    Any chance I could get a sketch of what you are looking for. Might be able to help.
    thank you
  1. Dust shoe - requirements and features
    By rvj2806 in forum Polls
    Last Post: Yesterday, 10:58 AM
  2. The Floating Dust Shoe (The best dust shoe out there)
    By Mopar71 in forum WoodWorking Topics
    Last Post: 03-12-2018, 02:16 AM
  3. 6040 CNC Machine dust resistance, and dust shoe
    By jm82792 in forum DIY CNC Router Table Machines
    Last Post: 06-02-2016, 10:42 AM
  4. Router / Dust shoe without vacuum or dust collector / Wind Deflector
    By ajean in forum DIY CNC Router Table Machines
    Last Post: 12-12-2015, 07:42 AM
  5. The Split Shoe - Dust Shoe
    By Kent23 in forum News Announcements
    Last Post: 12-06-2011, 07:26 AM
