603,365 active members*
2,880 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Nesting machined parts
    Dec 2005
    436
    I would like to nest machined parts.
    Can I specify a distance from one part to another. It seems that MCX2 controls the interpart distance.
    I am doing a simple nesting , constant offset in the X direction.
    Feb 2006
    992
    yes, transform toolpath..... as much time as you like.
    The best way to learn is trial error.
    Dec 2005
    436
    Distance between parts
    Quote Originally Posted by newtexas2006 View Post
    But how do I increase the distance between parts?
    Dec 2005
    436
    answer
    Quote Originally Posted by cncuser1 View Post
    I found Nesting>parameters>operations>part-part distance
    Apr 2003
    3578
    I was going to ask if you are using the nesting option or transform. then there is also Rectangler nesting and trueshape nesting options. But you found what you need correct?
    Cadcam
  1. Masking machined parts using vinyl
    By Brookway in forum Mass finishing equipment/media/strategies
    Last Post: 07-02-2007, 06:30 PM
  2. Rotating parts for nesting
    By millman52 in forum SheetCam
    Last Post: 04-11-2007, 09:59 PM
  3. RC parts machined wanted
    By tyrc racing in forum Employment Opportunity
    Last Post: 05-27-2006, 10:09 PM
  4. Turbine and compressor machined parts
    By xa_shall in forum Employment Opportunity
    Last Post: 11-04-2005, 07:02 PM
  5. Need parts Machined??
    By tizank in forum Employment Opportunity
    Last Post: 10-25-2005, 02:28 AM
