603,916 active members*
2,906 visitors online*
    199
    Anyone using the ESS and WarpRunner under Mach 3?
    I'm in the middle of setting up a new plasma build and am using the ethernet smoothsteper (ESS) along with the Warp 9 tech Warprunner THC.
    Their website STRONGLY recommends using Mach 4 and I have a license. I really don't want to make the switch as I find Mach 4 over complicated for the relatively simple stuff I do,
    Any real reason why the Warprunner won't work properly under Mach 3?
    Thanks!
    Is a sentance fragment?
    Nov 2013
    5409
    Re: Anyone using the ESS and WarpRunner under Mach 3?
    I think that there is no Mach3 plugin for the Warprunner.
    Craig
  1. Mach 4 with ESS
    By boydage in forum Mach 4
    Last Post: 01-30-2023, 04:52 AM
  2. MB3 ESS and MACH 4 two servos on one output not possible ESS reset velocity C
    By Gynaekologe in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2022, 08:31 PM
  3. Part's for Mach 3 PMDX ESS
    By upnorth in forum For Sale Only
    Last Post: 06-15-2021, 01:55 PM
  4. Mach 3 to Mach4 and ESS
    By Plasron in forum Controller & Computer Solutions
    Last Post: 08-30-2019, 03:16 PM
  5. Mach 3, ESS, Tormach 1100
    By andysims in forum Machines running Mach Software
    Last Post: 09-03-2015, 07:12 PM
