603,898 active members*
2,714 visitors online*
    199
    WarpRunner THC pulling away from material
    First day running new machine with ESS/Mach 4 and
    WarpRunner.
    THC isn't working properly. After 10 or 20 inches of cutting it's moving up away from the material until the Plasma cutter auto shuts off. The torch head is nearly half inch away from the material (.125 steel) when this happens.
    I get this message in the history window.
    !!!!!!ESS: Arc Okay (THC ON) WENT OUT!!! Activating Feed Hold now!.
    Must be something with setting?
    Is a sentance fragment?
    Aug 2018
    20
    Re: WarpRunner THC pulling away from material
    it went out because it was too far away from the material and lost defined voltage reading in THC , you have to figure out why it's too high, check Gcode perhaps?
  1. Anyone using the ESS and WarpRunner under Mach 3?
    By Tristar500 in forum Mach Plasma / Laser
    Last Post: 04-27-2023, 10:25 PM
  2. USB THC config missing THC box
    By rbmgf7 in forum SmoothStepper Motion Control
    Last Post: 01-24-2017, 05:06 PM
  3. HPR130. THC will not auto adjust to material height.
    By frostystones in forum Hypertherm Plasma
    Last Post: 07-30-2016, 06:35 AM
  4. Pulling hair out! Problem with material webbing.
    By xncrman in forum Vacuum forming, Thermoforming etc
    Last Post: 01-29-2011, 04:58 PM
  5. Pulling this off ?
    By twocik in forum Mini Lathe
    Last Post: 02-19-2009, 10:18 AM
