586,075 active members*
4,019 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Mitsubishi M-H 60 E Fanuc 16i-M Year 1998
    May 2023
    Exclamation Mitsubishi M-H 60 E Fanuc 16i-M Year 1998
    Help!!
    Have a Mitsubishi MH-60E that have lost all data. The machine is totally empty. The number on the machine is H53584. There are no saved backup. We have tried a backup from a newer machine. H53600 but itt still don´t work. We can´t get connection with the magazine (80 pots).
    We have the PC Parameter setting data on site in paperform but it´s the factory settings.
    Also got the NC options settings from japan to the specific machine. (parameterN9900 to N9989)
    Something is missing in the documentation.
    The ATC and APC settings.seems to work.
    But we can´t get connection with the magazine (80 pots). So M6 don´t work and we can´t search for pots in the magazine.
    We can step and run the magazine manually from the panel on the back of the machine.
    We have had conntact with Fanuc and a retired Mitsubshi expert that are on the case also.
    If some one have some kind off complete backup file to share we would be happy.
    If not we also will be happy suggestions to solve the problem.
    Apr 2009
    1379
    Re: Mitsubishi M-H 60 E Fanuc 16i-M Year 1998
    I am unclear what you mean with "we can´t get connection with the magazine (80 pots)". Maybe what you need are tool change programs (usually 8000 or 9000 program numbers). Where are you located?
    May 2023
    What we meen is that it is immpossible to do a toolsearch in the magazine. We got the original setting data to the spesific machine from when it was shipped from factory.
    But in the counter the preset value is 80 but we cant´t get in the correct value on current. From value 0 to 259 we get 0 when we insert. But if we insert 260 we getthe value 256. The Value should be between 0 and 80.
    The Tool change program we have from our other machine ( We have 2) and it is the same program.
    All other options work.
    We are located in Sweden.
  1. sodick a325, year 1998
    By suster in forum EDM Discussion General Topics
    Last Post: 04-18-2022, 11:05 AM
  2. Replies: 0
    Last Post: 03-05-2022, 06:40 AM
  3. Femco Durga 25E 1998 year/ Aligning Turrets Procedures
    By CNCWayToGo in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2020, 02:20 PM
  4. Replies: 3
    Last Post: 12-31-2015, 11:30 PM
  5. Mitsubishi EX8 SINKER 1998
    By Trill in forum EDM Discussion General Topics
    Last Post: 02-14-2013, 05:58 PM
