Hi friends,
I have a big problem, the quality of the surface finish at 45 degrees is extremely bad, the resolvers and tachos are new , but apparently the axis numbers become similar with a delay and lag.
What could be the problem?
Hi friends,
...SETP to Axis Lag ....then, check the Balance of X and Y ..Program O5811- O5815
https://nxgenparts.com/content/Maint...e_Programs.pdf
...go into SETP at Comman Line...hit the Space Bar twice and on page3 go to AXIS DISPLAY and set to ERR.
then run this Service Program
O5811-Balance should be Inch:BALLSCREW 595, Metric BALLSCREW 700ipm: 302
N1 O5811 (BALANCE INCH:BALLSCREW 595, METRIC BALLSCREW 700IPM: 302
N2L100
N3M49
N4X5.Y5.Z-5.G1F150.
N5X-5.Y-5.Z5.G1F150.
N6M17
N7M30
N8M91G91(START OF THE MAIN PROGRAM
N9(
N10(*FOR INCH BALLSCREWS:
N11(BALANCE ALL 3 AXES TO 595 ON THE DISPLAY OR 1.44 VDC
N12(AT THE COM AND SIG2 LUGS OF THE AXIS AMPLIFIER
N13(*FOR METRIC BALLSCREWS:
N14(BALANCE ALL 3 AXES TO 302 ON THE DISPLAY OR .735 VDC
N15(AT THE COM AND SIG2 LUGS OF THE AXIS AMPLIFIER
N16(
N17(
N18L101.1
Axis thrust bearings are a common wear item on Fadals. The first evidence is usually quadrant lines during circular interpolation. It can also express as less than great finishes during angular moves.
My $0.02 (US)
...have you checked power supply Voltages and the AC Ripple...follow Chapter 11 Troubleshooting for more things to check.
https://itscnc.com/pub/media/documen...leshooting.pdf
