603,358 active members*
3,582 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Dynapath Delta 20 handwheel not working
Results 1 to 10 of 10
    Jan 2019
    60
    Does anyone have any tips for troubleshooting a handwheel that isn't working?
    My Delta 20 has a handwheel on the panel, and while in jog mode, I have the soft button for "select handwheel axis". When I press it, it cycles through x, y, and z axes. But, turning the handwheel doesn't jog any of the axes regardless of selection.
    Hoping someone can shed some light on whether I'm doing something wrong, or how to fix it
    Thanks in advance
    Lee
    Aug 2009
    1573
    Re: Dynapath Delta 20 handwheel not working
    ...you are doing it right so, must be something not working with Hand Wheel unit....check to see if, wiring is ok going from the Interface board Plug...check for voltage to Unit...if, it has 5vdc voltage....then the light bulb inside is bad and have to be replaced.
    Jan 2019
    60
    Quote Originally Posted by machinehop5 View Post
    Hi machinehop,
    Thanks for the reply. I checked the voltage to the handwheel, and it's getting 4.8v. I'm a little confused about the lightbulb though - this is a handwheel on the control box, not a pendant.
    I've attached a picture of the connections on the back of the handwheel, and the wiring diagram, and they look correct to me. I don't know much about electronics, though, and not sure what to do next in terms of troubleshooting.
    Appreciate any guidance!
    Lee
    Attached Thumbnails Attached Thumbnails Screenshot_20230826_153515_Drive.jpg   20230826_152846.jpg
    Aug 2011
    121
    leeko,
    With a voltmeter you can check if the handwheel is generating the right signals. The handwheel will produce a sequence of pulses on terminals 3 and 5 as you rotate the wheel. Use the following procedure to verify operation:
    1) Set your voltmeter to read signals of at least 5 volts
    2) Terminal 2 will be the ground reference for all the readings (black probe here)
    3) Check voltage on terminals 3 and 5 and note down
    4) Move the handwheel one click and repeate and note voltages as in step 3.
    5) Repeat (4) until you have read the voltages for 4 positions of the hand wheel.
    What you are looking for in a properly working hand wheel is a sequence of voltage changes where exclusively one terminal changes voltage on each click.
    This means for instance that the outputs would do the following:
    (T3,T5)
    (lo, lo) - click 1
    (lo, hi) - click 2
    (hi, hi) - click 3
    (hi, lo) - click 4
    hi would be a voltage close to 5V, lo would be close to 0V.
    One and only one terminal changes state for each click.
    RT
    Jan 2019
    60
    Hi
    Thanks very much for that
    I'm not seeing any voltage between 2 and 3, or 2 and 5,. No matter how many clicks. Does that mean the handwheel is toast?
    Lee
    Quote Originally Posted by cngbrick View Post
    leeko,
    (T3,T5)
    (lo, lo) - click 1
    (lo, hi) - click 2
    (hi, hi) - click 3
    (hi, lo) - click 4
    RT
    Aug 2011
    121
    Possibly dead as machinehop5 said -- the handwheel is optical inside with a lamp illuminating a grid wheel. If that lamp goes out there will be no output. Try the measurement on the complementary terminals (T2 to T4, T2 to T6) and see what you get.
    RT
    Jan 2019
    60
    RT
    I got nothing on any of the terminals, so I started dismantling to get to the lamp. I give up - how do I get into this thing? I took out all the screws, but it seems like the thing is pressed together pretty snugly. I don't want to blindly pry anything apart and potentially damage something...
    Attached Thumbnails Attached Thumbnails 20230826_223756.jpg   20230826_223747.jpg   20230826_223741.jpg
    Aug 2011
    121
    They are not really intended to be serviced, an experienced instrument repair person could possibly manage it. Easier to find a replacement.
    There are probably some low-cost units that you can fit without too much difficulty. You are looking for a 100 PPR (pulse-per-rev) unit that can take a 5 VDC supply. The unit can be either single-ended or complementary output depending on which is easier to source as Dynapath only uses the positive output terminals. Check on popular auction or internet store sites.
    RT
    Aug 2011
    121
    If you do want to open it, there are probably screws under the label or simply removing the standoffs each side of the terminal block will do the trick.
    RT
    Jan 2019
    60
    RT
    I opened it (the standoffs, like you said), and quickly determined that repairing it is beyond my skill set. I have an eBay pendant ordered and on the way.
    Thanks again!
  1. Replies: 1
    Last Post: 02-15-2017, 01:02 AM
  2. Replies: 6
    Last Post: 02-08-2015, 06:18 PM
  3. dynapath delta 20
    By alex2008 in forum DNC Problems and Solutions
    Last Post: 11-09-2011, 11:22 AM
  4. Dynapath Delta 20
    By chipman in forum DynaCNC
    Last Post: 06-14-2011, 01:41 AM
  5. dynapath delta
    By josalomo in forum Surfcam
    Last Post: 12-18-2008, 05:34 PM
