603,308 active members*
3,264 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Mar 2013
    19
    Check My Wiring Diagram
    https://www.digikey.com/en/schemeit/...656fe687352808
    Can anyone who knows what they are doing critique my wiring schematic and see if I am doing this right? Also, if this is in the wrong spot please let me know.
    This is a homemade router with an MB3 breakout board
    Jun 2005
    1779
    Re: Check My Wiring Diagram
    The digikey drawing app is so slow it is hard to examine your drawing. Try and convert drawing to a pdf so anyone can view easier
    24260
    Is there an E-Stop in there somewhere?
    Didn't see one, unless i missed it, a little hard to read.
    Albert E.
    Mar 2013
    19
    https://www.dropbox.com/scl/fi/6edoq...rrsmyswj9&dl=0
    Here is a link to the PDF file. This should help.
    @cncman172 - I put the estops inline after the off button to kill the main power contactor that powers the 48v power supplies for the drives. Is this the right spot? I have seen some setups use an input on the MB3 board but I am not sure how that works.
    Jun 2005
    1779
    Quote Originally Posted by cspearsall1 View Post
    The way you show your estop which kills source power to contact or will work. You diagram suggests your spindle is 110v is that correct. I have the same breakout board as you with the ESS
    Mar 2013
    19
    Yes, the "spindle" is just a Porter Cable 3.25 HP router at the moment. I have aspirations to upgrade to an ATC spindle one day but for now this will have to work. I have seen some wiring diagrams that use the estop with a pin on the MB3. How is yours wired?
    Nov 2013
    5403
    the only thing I see that is missing is a catch diode on the spindle relay. The inductive voltage spike when the relay de-energises will wreck the output of the MB3,
    and really spoil your day.
    Craig
    Jun 2005
    1779
    Craig
    In addition to the diodes on the relay to avoid spikes, I would also add EMI filters on the incoming AC power, to avoid EMI interference which will drive your machine crazy, with all kinds of unexpected motion.
    Mar 2013
    19
    @cncman - would this work for an EMI filter or do I need something else?
    https://a.co/d/3DNp62B
    @craig - I have no idea what a catch diode is, but Google did. So it acts as a one-way gate to not allow voltage back into the controller board from the relay? If you don't mind, can you explain where in the circuit this would be wired and what size I would need for a 15a 100v motor on a relay?
    24260
    That is good for up to 30amps, R/L/C filters work well to clean up the power line.
    Albert E.
    Mar 2013
    19
    Jun 2005
    1779
    Yes, that filter will work fine
    Nov 2013
    5403
    how about posting a wiring diagram I can see?
    That filter will work but its only single stage, it should be two stage.
    Craig
    Mar 2013
    19
    Sorry Craig,
    Hopefully this is better quality:
    https://www.dropbox.com/scl/fi/px7s9...9e24f783s&dl=0
    Nov 2013
    5403
    NO! Do not put a diode anywhere near the spindle.
    A catch diode goes on the coil terminals of the relay.
    Scheme-it-export-CNC-Wiring-2023-09-27-07-44 (edited) (1).pdf
    Craig
    Mar 2013
    19
    The link to the PDF isn't working for me.
    Nov 2013
    5403
    The catch diode goes between the coil terminals of the relay. Note the polarity, its important.
    Craig
    Mar 2013
    19
    Got it....thank you!!!
    Mar 2013
    19
    Still working on the router https://www.icloud.com/photos/#090k3...DLRkzp_W2frZ9w
    To recap:
    a friend and I built 17 years ago. it sat at his place for 15 years unused. I recently went and picked it up and began the process of bringing the phoenix back from the ashes.
    I completely replaced the control electronics including an ESS Smoothe Stepper with an MB3 Break Out Board.
    The wiring is complete (I hope) and I have installed Mach4 and began configuring it. I have got all of the limit and E-stops configured but I cannot get the steppers to move.
    A couple of notes:
    I do not know anything about the stepper motors except they are NEMA34 and were purchased 17 years ago
    I purchased new stepper drivers DM556T from Steppers online and have them installed and wired to the motors
    The drives have holding power but will not move
    The step and direction pins light appropriately when using the jog screen in Mach4
    There is 48v power on the outside pins of the outputs for the stepper drivers (one for each winding)
    Any help in diagnosing this would be appreciated.
    Jun 2005
    1779
    To recap:
    A couple of notes:
    Look at the manual for the drivers. Many stepper drivers have some pins to enable them. You usually need to ground the enable signal but check your manual
Page 1 of 2 12
  1. wiring diagram
    By prabhu58 in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2019, 08:19 AM
  2. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
