603,310 active members*
2,296 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Just bought a Plasmacam with no software - best options?
    Oct 2023
    I just bought a ten year old as new Plasmacam table - unfortunately without pc or software.
    Plasmacam say they will transfer the ownership, but that the software that goes with my machine is no longer supported or available. Seems like manufactured obsolescence to me. New software from them would cost $2000 which I'm not keen on spending in order to get on their treadmill. The machine only cost me £1070 off Ebay!
    I'm looking at my options:
    1. Upgrade using the C&CNC kit (if they will ship to the UK) which is expensive but ticks all the boxes.
    2. Fit Geko G320X drivers for the X & Y, generic stepper driver for the Y, and then upgrade using the Myplasm kit and software. This looks very user friendly but would need more work and setting up than opt 1.
    3. Use Geko drivers and a generic 3 axis CNC controller, Mach 3, and Sheetcam. This is a bit cheaper than option 2 but would entail a lot of work and setting up etc.
    4. Very reluctant to swap out the servos for steppers and then use controls as in opt 3.
    I suspect lots of people will have been through this process and any advise or comment on my options (or others I should be considering) would be most welcome.
    Thanks in advance for any input.
    Nov 2013
    5404
    Re: Just bought a Plasmacam with no software - best options?
    firstly, what servos and servo drivers does the machine have currently?.
    It certainly makes sense to reuse those servos if reasonable and cost effectively possible. If they are Step/Direction servos that does not preclude the use of Mach3, although Mach3 is obsolete.
    If you want to use Mach then get Mach4. I have used it and an Ethernet SmoothStepper for eight years and its light years ahead of Mach3.
    Assuming the servos are Step/Direction and you want to replace the control system then I'd recommend Mach4 (200USD), Ethernet SmoothStepper ($225USD) and a WarpRunner ($449USD).
    The last component (WarpRunner) is a breakout board and THC controller combination. It is designed to work specifically with Mach4 and an Ethernet SmoothStepper and offers high dynamic THC (high bandwidth)
    with sophisticated Anti-Dive strategies, offering as good a solution to hobbyists (for Plasma THC) as many a commercial or industrial solution.
    Craig
    Apr 2004
    5948
    Does it currently have stepper motors or servos? The Gecko G320 drives will run brushed servos, but if your machine has steppers, you'll want another kind of drives.
    Andrew Werby
    Website
    May 2015
    686
    I would consider a retrofit to linuxcnc.
    But I think the servos they use are a bit non standard
    Also I believe the Z axis lifter uses a proprietary serial comms link to the motor.
    Upgrading the licence could well be a cost effective solution.
    Rod Webster
    www.vehiclemods.net.au
    Jun 2024
    6
    Are servos or stepper motors installed at this time? Brush servos can be driven by the Gecko G320 drives, while steppers require a different type of drive.
  1. Replies: 4
    Last Post: 03-20-2024, 11:49 PM
  2. $15k for PlasmaCAM? Any other options for Israel?
    By activefarming in forum Waterjet General Topics
    Last Post: 01-20-2016, 11:43 PM
  3. Replies: 4
    Last Post: 01-03-2014, 06:52 PM
  4. What are my options? Just bought an X3 from harbor freight.
    By bassmanss in forum Benchtop Machines
    Last Post: 02-01-2010, 02:06 PM
  5. I just bought an ESAB PCM 150 for $750. Torch options?
    By semi-lucid in forum Waterjet General Topics
    Last Post: 03-04-2009, 12:50 AM
