603,785 active members*
17,855 visitors online*
    Dec 2004
    84
    E-Chain Installation
    Hi all. I'm about finished building a Solsylva cnc (36"x49" table) and am curious if anyone has any words of wisdom about installing some e-chain (Igus or Kabel Schlep). I'm especially curious if there is a minimum width to allow for some distance between the motor cable(s) and the limit switch wires. What would be the minimum distance of separation between them?
    Thanks for any insight you may have.
    Best regards,
    Mike
    Dec 2004
    411
    Mike,
    I'm very interested in the response that you get and I hope this thread will elicit some good content.
    To date, the single most important aspect that I have discovered is that your power leads need to be twisted pair. To me, that makes good sense as I recall that emf gets cancelled out with twisted pair.
    Beyond that ..............
    Andy
    Drat, imperfection has finally stopped working!!
    Dec 2004
    84
    Thanks fpr the response, Andy. I wondered about the effects of twisting the wires, too. We do that often in R/C airplanes with long leads to the servos.
    Best regards,
    Mike
    Apr 2007
    8082
    mcyr,
    The easy way to twist the wires is to clamp one end of the wires in a vise of some sort, make the wires as parallel as possible, put the other end of the wires in the drill chuck of a variable speed drill and wind the wires up evenly. One turn per two inches after removing the drill is enough. If you wind the wires very tightly there will be more capacitance between the wires that may change the pulse shapes of higher speed signals traveling in the wires.
    Wind the limit switch wires also, but reverse the winding direction and the two sets of wires will interact even less.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  1. Chain cutting
    By millman52 in forum BobCad-Cam
    Last Post: 09-12-2007, 12:44 PM
  2. autocad installation ?
    By coonhunter in forum Computers / Desktops / Networking
    Last Post: 09-10-2007, 04:56 PM
  3. HELP Please: New Ballscrew Installation
    By vacpress in forum Linear and Rotary Motion
    Last Post: 03-31-2006, 11:07 PM
  4. E-chain
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 03-11-2006, 06:12 PM
  5. Project a chain
    By HuFlungDung in forum OneCNC
    Last Post: 05-23-2003, 12:57 AM
