603,310 active members*
2,400 visitors online*
    Apr 2004
    14
    Transmission Ratio calculation help
    I have an AXYZ router I am retrofitting, Working on Pulse per inch calculations, I found info that is close but not sure how the math works
    Paperwork on a similar model says...
    Transmission Gear Ratio
    24 Tooth Pinion Effective Diameter: 1.2 inches (30.48 mm)
    Main Pulley: 60 tooth
    Minor Pulley: 18 tooth
    Transmission Ratio: .88422 REV/INCH / .3481 REV/CM
    (I believe this works out to 3.33 : 1 Ratio)
    My question is what is the formula to get the Rev/Inch number calculated to be .88422 ?
    Pinion Gear / Track is 20 DP/Module 20 Pressure Angle
    In my case I actually have
    Minor Pulley: 24 tooth
    I believe this works out to 2.5 : 1 Ratio
    What is the Calculated Transmission Ratio with the 24 tooth Minor Pulley vs the 18 Tooth Minor Pulley
    Trying to calculate my Exact steps per inch, 3183 Pulses per Inch is really close but not sure its exactly right
    Servo Driver is set to 3000 Steps per unit
    Any other info needed?
    Thank You
    Ed
    Mar 2024
    Re: Transmission Ratio calculation help
    Hi Ed,
    You need to multiply the PD of the pinion by pi to find the pitch circumference.
    1.2*pi=3.77" per revolution
    Divide by your transmission ratio
    3.77"/60*24 = 1.508"/rev = 0.6631 rev/inch
    Regards,
    Zach
  1. Ratio Calculation For 3 pulleys
    By Mcyoda in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2010, 02:30 PM
  2. help with ratio....please
    By Grunge-Fut in forum Waterjet General Topics
    Last Post: 09-09-2008, 07:33 AM
  3. ratio on x y table
    By dgalaxy in forum Machines running Mach Software
    Last Post: 06-25-2006, 03:40 AM
  4. gear ratio help
    By Erick Davidson in forum Waterjet General Topics
    Last Post: 05-30-2006, 04:04 PM
  5. Gear ratio calculation spreadsheet
    By Splint in forum Community Club House
    Last Post: 07-09-2005, 04:49 PM
