603,836 active members*
2,955 visitors online*
    Nov 2007
    Data server question
    Is it possble to edit a program in a fanuc data server?
    Because of program size we are drip feeding a program from a data server into the machine's control. Everything is great untill we have to edit or search through a program. The time it takes to search through a program that is running off a data server is too long (similar to searching while the machine is in memory mode). Normal if we are using the cnc to store the program we can just search in edit mode which is alot faster.
    If we could search or edit in the data server, speed would not be an issue
    Machine is a Makino with a Fanuc 16MB control.
    Program length is about 2Mg
    Noel
    Feb 2004
    142
    you cannot edit information on a dataserver... that's a limitation to that type of technology. is it a large contouring program or just a large program with a lot of operations? could you split everything into subprograms?
    Nov 2007
    Yes and Yes
    Every part is one off and presently our programming automation will not put anything is sub programs.
    Thanks for your input, Noel
  1. Fanuc 18i with Data Server
    By Monty66 in forum Fanuc
    Last Post: 02-13-2007, 04:23 AM
  2. Dnc server
    By PSIman in forum DNC Problems and Solutions
    Last Post: 07-18-2006, 02:51 PM
  3. It's an ad server
    By doug6949 in forum Uncategorised CAD Discussion
    Last Post: 07-25-2005, 05:38 PM
  4. RPC Server?
    By BIGFERB in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2004, 02:41 PM
  5. Is the new server faster?
    By cncadmin in forum Polls
    Last Post: 03-14-2004, 02:03 AM
