587,752 active members*
3,345 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Toolroom Mills: $5000 for 4"?
    Jun 2006
    29
    I am about to purchase a Haas toolroom mill. I am torn between the TM-2 and the TM-3. $5000 is alot of money for an extra 4" of Y axis, IMO. I am curious what you guys think. Also, I would like to know what owners think about these two models as far as rigitity cutting steels, part repeatability......you know..the works. Thanks.
    Jul 2004
    601
    Well I only have a tm1 but the drives and spindle are the same on the tm series, and I'd think rigidity woul also be comparable. I cut steel plate, 1045, 1018, and a little 4140. I can slot with a 3/4 insert mill .1" deep at 18-20 ipm, and shoulder at .1" deep and up to a 1/2" pass at about 30ipm (60-75 % spindle load @3055 rpm). The tool and spindle will do more but the machine starts to vibrate when you go much past that. In aluminum (6061) I can go as deep as I dare and bump the feed rate up untill my spindle is %100+ (.2 slot at about 100-120 ipm). I've bumped the spindle up to 6000 rpm.
    I find it's repeatability as good as your setup. The best job to show this was some large pillow blocks I had to interpolate out to a -.001 press fit. I needed to go 3.25 deep, about 6.5" dia, and once I had the tool dialed in I did 6 blocks and needed to tweak the tool offset once (.0005).
    Flood coolant on these machines can get messy. The back guard leaked like mad, and the Haas tech used a pop can to make a coolant tent over the y axis limit. A tube of silicone got most of the leaks down to drips. Once you admit to yourself these aren't enclosed vmc's the factory coolant guards do a pretty good job of keeping the mess contained.
    Do you need the extra 4"? Are you sure? Extra travel is always nice. If you decide on a tm2 get the tool changer (also recomended on the tm3), you are probably like me, and thought you can live without the extra expense. This changed when I did 300 changes in about 5 hrs... Even the manual tool change is better than screwing around with an r8.
    Whatever you decide these tm's are a great bang for the buck, you just need to work within their limits. Make sure you have a good tooling budget to get going (they are more expensive than drugs). I've had my mill for about 8 months and have about 10k in tooling now.
    Good luck
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
  1. Haas Tl-1 Toolroom Lathe
    By DEAN in forum Haas Lathes
    Last Post: 10-11-2012, 10:25 PM
  2. ABOUT HAAS Toolroom mill 1H
    By marto74 in forum Haas Mills
    Last Post: 09-12-2009, 07:06 PM
  3. Need help on a Haas TL-1 Toolroom Lathe
    By tidle73 in forum Haas Lathes
    Last Post: 11-06-2008, 03:49 AM
  4. FS: 2006 Haas TM-1 Toolroom Mill
    By Edster in forum Haas Mills
    Last Post: 01-22-2007, 04:20 PM
  5. Replies: 5
    Last Post: 04-12-2005, 09:40 AM
