586,670 active members*
3,257 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Is there a single-line, connected-text font in SHX,SHP,LFF format?
Results 1 to 8 of 8
Threaded View
    Hello,
    I have found an enormous amount of posts on single-line fonts for CNC and how to get free SHX fonts for AdobeCAD, etc. But I am having a really hard time finding a single-line connected-text font that comes in a CNC friendly format, like SHX, SHP, or LLF. I would also be fine if it was in DXF paths.
    What I need is to make a single pathway for my text, one single line, starting left, going right, and connected so that the single line is drawn without lifting the bit.
    This single-line (ish) connected-text font is best exemplified by a font I found on FontSpace called I am oneline with U I have attached a sample image of this font to show how it's single-line and connected.
    Sadly, this font is only available in TTF or OTF formats which always come as closed shapes on a plane. They are not truly single line. So converting to SHX or what I originally tried to do which was convert to DXF using Python's ezdxf text2path add on, I always get a single-line outline of the text, not a single-line left to right. So effectively all the lines are doubled up, inside and outside.
    Is there anyway to convert the above font to a truly single-line font, or does anyone know of a single-line *and* connected-text font that works this way?
  1. Single line font
    By ErnieD in forum BobCad-Cam
    Last Post: 01-10-2021, 01:24 PM
  2. Replies: 0
    Last Post: 02-28-2018, 09:44 PM
  3. Single line stencil font
    By Huaco in forum Uncategorised CAM Discussion
    Last Post: 06-20-2011, 06:53 AM
  4. SINGLE LINE FONT
    By xxshuaxx in forum Engraving Machines
    Last Post: 11-30-2007, 05:05 AM
  5. Single Line Font?
    By squarewave in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 01:03 AM
