603,347 active members*
2,909 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Drive Surface Distortions on 4-axis machine
    Nov 2013
    47
    Hi all, I am writing to try and get a better handle on some unexpected (and unwanted) aspects of using DriveSurfaces on 5Xtra. Is there a way to limit the toolpath generation to just 4 axis? The posts come out fine, but are always a bit smushed in the X (trunnion) direction if the drive surface has an slope in this direction and these deformations show up on the workpiece. It seems that the toolpaths are being calculated as if they were being cut with a 5 axis machine where the tooltip would be normal to the surface. This is illustrated in the view from the Top Cplane where the surface being cut is the drive surface, but the tool path does not reach either end due to the surface's convex shape in the direction of the A axis.
    Any direction, suggestion, insight, or better yet solution to this problem would be extremely helpful. Many thanks, O
Name:	Screenshot 2024-03-04 155321.jpg
ID:	502496Click image for larger version.
    May 2006
    367
    Re: Drive Surface Distortions on 4-axis machine
    Have you tried 5x revolution toolpaths? They are simultaneous 5 axis, but the 4th axis does most of the work, the 5th only moves a few degrees.
    In 5x mode, I draw a "spindle line" and a "revolution line" for reference, then I use these lines to click on in the 5X revolution box.
    May 2006
    367
    I forgot to mention if you strategically place/angle these reference lines... it limits rotation.
    Nov 2013
    47
    Coming back to this. Turns out you are very correct about the 5X revolution toolpaths. They do a lot of heavy lifting. They get a little odd when your geometry gets too swoopy, but it is great for a lot of applications. In addition to using the lines I am finding I get a bit more precision if trying to hit a specific part from a certain angle in a small region, say between curves, it is helpful to generate the toolpath and then rotate it about the A axis to tweak the angle.
    I've been back to the drive surface this month though and have a hypothesis that the uniformity of the drive surface isocurves may be just as responsible for distortions (less equal spacing = less precise output) as anything. Have you found this at all to be the case? Maybe Joakim or someone with more insight to the inner workings of MadCAM could chime in. Thanks for reading! -O
  1. Replies: 0
    Last Post: 04-13-2021, 04:00 PM
  2. 4-axis CNC machine RC1325RH working on curving surface
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 09-20-2019, 01:58 AM
  3. Replies: 0
    Last Post: 05-21-2017, 04:37 AM
  4. Latest madCAM making 4 Axis Drive Surface
    By Mauri R in forum MadCAM
    Last Post: 05-21-2017, 04:29 AM
  5. Sim 5 axis doesn't work: says there's no drive surface
    By greg2fs in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-04-2015, 03:29 PM
