603,940 active members*
2,221 visitors online*
Results 1 to 1 of 1
Threaded View
automationtechinc 3015 FIBER LASER METAL SHEET... 03-23-2024, 06:50 PM
    3015 FIBER LASER METAL SHEET CUTTER 2000W
    We are going to have a 3015 FIBER LASER METAL SHEET CUTTER 2000W in stock at Chicago warehouse about 30 days. if you have any question, pls let us know
    https://www.automationtechnologiesin...sheetcutte2000
    Working Area: 59" x 118 " (1500 mm x 3000 mm)
    Control System: CypCut E, BoChu FSCUT2000E controller
    Industrial Computer
    Max Laser Generator 2000W
    Laser Head: RayTools BM110
    Driving System: Delta 750W Servo Motors for X, Y, 400W for Z
    Dimension Tolerance: 0.05mm
    Positioning Tolerance: 0.02mm
    High Quality Rack and Pinion Guide Rails
    Italy MOTOVARIO Gear Reducer
    Cooling System: Water chiller Hanli 60HZ 2KW
    Transformer 220v 3ph - 380 3ph 40kva
    Stabilizer ( Or Regulator) 380VAC 50kva
    Air-Assist: Oxygen or Nitrogen
    Nitrogen proportional valve and Oxygen proportional valve
    Machine Power Supply: Three Phase 220 V
    Power Consumption: 15-20 kW
    Gross Weight: 9850 lbs
    Cutting nozzle: 30 pcs, Protective lens: 25pcs, Ceramic ring : 5 pcs
    Dedicated USA technical support from qualified technicians and engineers
    Warranty: One Year Parts
