586,103 active members*
3,398 visitors online*
    Feb 2006
    170
    Enroute 3 post processor for TurboCNC
    Hi
    I need a Enroute 3 post processor for TurboCNC or can I modify a machine driver to suit my needs.Im new to TurboCNC after ditching Mach 3 because of endless problems.What file format do my G code files need to be in for TurboCNC to read them, I am using Enroute 3 to generate my toolpaths.
    Pls Help
    Edmond
    Mar 2004
    1806
    Generally speaking, Turbocnc uses the RS-274 D "standard" for codes. Your best bet is to review the doc. file as it will give you the info you need.
    Can't help you with Enroute as I don't use that one.
    The biggest thing is to get the extra parameters correct for some of the functions. The manual can be found on the home page http://www.dakeng.com/ about 3/4 of the way down.
    Art
    AKA Country Bubba (Older Than Dirt)
    Dec 2007
    25
    Enroute postprocessor
    Do you have the Enroute postprocessor for Mach3?
  1. bobcad post processor for turbocnc
    By Pbrew1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2018, 08:26 PM
  2. enroute pro 3.3 post for fanuc 0Mb needed
    By goodplastics in forum Uncategorised CAM Discussion
    Last Post: 08-08-2007, 05:47 AM
  3. mastercam post for turbocnc 4
    By jaypal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-12-2006, 12:30 PM
  4. Gibbs post for turboCNC?
    By gjahnke in forum GibbsCAM
    Last Post: 03-10-2006, 01:46 AM
