587,021 active members*
4,642 visitors online*
    Sep 2019
    26
    Weldon Spindle assembly help
    I have two (2) weldon endmill sharpeners that a highschool robotic team students dissembled to "see" how they worked. I need to reassemble them. The bearing has been removed from the frame. I had five (5) other spare bearings which they mixed up with the originals. Is there a way to reassemble these things ?
    I've heating the outer bearing to about 120 degrees with no joy. I'm not sure how hot I can get them or if this is the correct way to get them back together. Are they lapped to the spindle and only fit the original pair ?
    thx for any suggestions
    -g
    Sep 2019
    26
    Re: Weldon Spindle assembly help
    I got both of them back together. The size of each spindle is a slightly different size by seven (7) tenths. The two sizes I have are 2.1881 and 2.1888. The sleeves are between 2.1573 and 2.1103. Two (2) sleeves are about 0.003 larger than the spindles which was a tight fit.
  1. Weldon air spindle
    By ozzie34231 in forum Toolgrinding / Toolgrinding Machines
    Last Post: 07-26-2023, 06:08 AM
  2. ATC Spindle Assembly using a Chinese BT30 Spindle Cartridge
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2020, 08:31 PM
  3. Pushing spindle assembly too far?
    By danielcoyle in forum Commercial CNC Wood Routers
    Last Post: 08-02-2013, 04:37 AM
  4. R8 spindle box assembly
    By bmx4637 in forum Benchtop Machines
    Last Post: 05-04-2011, 05:02 AM
  5. Weldon vs Collet
    By dhiruj in forum CNC Tooling
    Last Post: 05-19-2007, 12:45 AM
