603,954 active members*
3,118 visitors online*
    Apr 2024
    Alarm 501 OT Won’t Go Away
    I’ve been having an issue with a KOIKE Laser, 2005 model. It has a FANUC 160 series control. It is throwing a 501 alarm due to a V axis over travel. The machine is locked until the alarm is cleared. Manually moving the head backwards and resetting does not work. The servo motor cannot be manually moved back without doing it from the control and that cannot be done because of the alarm. What options do I have for manually overriding the alarm?
    Apr 2024
    Over travel alarm on 2005 KOIKE Laser won’t go away. It is a V axis over travel. We have manually moved the head but that will not work because the computer is not recognizing the head has been moved but we can’t move the motor back from the control because of the alarm. What options do we have to manually override the alarm?
    Re: Alarm 501 OT Won’t Go Away
    If you hit a hard overtravel switch, check that it's not stuck in the actuated position. They can go for years without being touched, then one day they get hit. You might get stuck if you hadn't moved in years too. :-)
    Jul 2024
    7
    hello I have a biglia digital lathe fanuc control and yesterday I received a message 910 Parity Error (low) I change the batteries and then I received an error message
    417 servo alarm x
    427 servo alarm z
    someone help me find the parameter list
    thanks
  1. Replies: 1
    Last Post: 10-22-2020, 01:05 AM
  2. MSG 501 parameter write enabled alarm
    By cheatmaster300 in forum Mori Seiki lathes
    Last Post: 10-24-2015, 05:54 AM
  3. Hardinge Talent 501 Alarm
    By debpurdy in forum Fanuc
    Last Post: 12-20-2013, 05:28 PM
  4. TL-1 door open alarm won't go off!
    By donsbad89 in forum Haas Mills
    Last Post: 09-25-2009, 04:01 AM
