Re: make simple 2d tool path and gcode fusion 360
Originally Posted by
rccars4sal
I have been trying to generate g code, but the fusion just keeps saying tool path not supported by the selected tool. Is it wrong to select 1/8" flat endmill for a simple profile outline?
I know what some of the issue is. Fusion wants to calculate offsets, feeds and speeds, and it thinks I am wrong. All of that is stupid.
My drawings are such that tool offset is calculated into the line work. I edit feeds and speeds for every run because I use different materials, wood, carbon fiber, fiberglass, delrin, nylon.
I would have to see one of the drawings that this error is occuring on. Export a F3D file, zip it and attach it to a post.
Calculating feeds and speeds is what Fusion kind of does, but Edit the Tool to make adjustments
If you have already done the tool offsets in the DXF file, then use the Trace operation to do the part. It cuts exactly where the line is.
I should note here that Fusion CAM wants to see a 3D part, not a 2D line drawing. Try extruding the part you are working on, then run it through the CAM function.
Jim Dawson
Sandy, Oregon, USA
