603,929 active members*
3,968 visitors online*
Results 1 to 6 of 6
    Sep 2006
    20
    pminmo BOB and NC E-Stop switch
    I have a BOB built and everything is running great. Except that I do not have an E-stop switch hooked up yet. I have some excellent take-out components from some equipment and would love to use what I have. Unfortunately, the E-stop switch is a NC switch, and the circuit calls for a NO switch. Is there a way that I can change the circuit to use it?
    I was also thinking that having the circuit take NC switches would be a safer method. This way I could hook up several switches in series, and then any single switch would cause the circuit to stop.
    Any suggestions?
    24260
    E-stop circuits are generally wired with NC devices as a safety precaution. Also it conforms to the code recommendations.
    You can change the logic by using all the NC safety devices in series and they would pick up a relay with a NC contact, this contact would be open in normal operation, closed on e-stop.
    Al.
    Albert E.
    Sep 2006
    20
    Here I was trying to figure out a complex circuit to use the thing, and never thought of a relay. Leave it to someone else to point out the obvious.
    Thanks Al!
    Jun 2003
    3312
    You can use a normally closed switch, in fact it is preferred. Not sure where I might have communicated that you can only use normally open?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Sep 2006
    20
    Maybe I am misinterpreting.
    If the switch is closed, the circuit latches (all the time, unless the switch is pressed). If I press the reset switch, it momentarily un-latches (machine could run), but then latches again. I tried simply changing the way that Mach3 sees the signal, but no good.
    Am I doing something wrong?
    Jun 2003
    3312
    Oh, your referring to the website version, I didn't think about that one. Too many days have passed..... Skip the circuit, just use Pad 15 as the input, the other side to a gnd pad.
  1. Webhost problems PMinMO.com
    By pminmo in forum Community Club House
    Last Post: 10-17-2007, 06:45 AM
  2. Pminmo electronics
    By SCHootie in forum Open Source CNC Machine Designs
    Last Post: 02-23-2007, 04:40 PM
  3. Questions for pminmo
    By dfro in forum CNC Machine Related Electronics
    Last Post: 07-02-2006, 04:14 AM
