603,942 active members*
2,347 visitors online*
Threaded View
multiplex another first time build! 11-19-2007, 08:11 PM
multiplex well i've gotten a little... 11-29-2007, 04:19 AM
    Nov 2007
    197
    Hello everyone. I've been lurking the forums for a little now, and am about 1/2 way done the construction of my first table.
    I'm planning on learning the hard way, and am sure there will be some design flaws along the way.
    The main construction of the frame is 2" x 2 1/2" angle iron. Mounted underneath are two 55" vbx 20mm rails. The main gantry is contructed from 3/4" pvc.
    I realized my first flaw this weekend after assembling some components. The Y axis has alot of flex in it. The unsupported 20mm rods can't handle the span.
    So those are on the way out, and will be replaced with another set of supported 20mm rails.
    Overall travel will be 49 x 44 x 8
    movement will by by 425oz steppers, and 1/2"-10 2 start acme rod.
    Let me know your thoughts!
  1. Yohudi's Build log - Time to get stuck in
    By yohudi in forum CNC Wood Router Project Log
    Last Post: 09-25-2008, 06:41 AM
  2. My Second Router Build This time Joe's CNC Model 2006
    By Catapultsup in forum Joes CNC Model 2006
    Last Post: 08-17-2007, 04:17 PM
  3. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  4. DIY - Build CNC for the first time
    By XenC in forum Open Source CNC Machine Designs
    Last Post: 12-21-2006, 12:48 PM
  5. 3rd CNC ROUTER BUILD time to get serious.
    By Oldmanandhistoy in forum CNC Wood Router Project Log
    Last Post: 02-22-2006, 11:41 PM
