586,082 active members*
3,871 visitors online*
    18
    Array with v20
    Is there a way to array with bc 20?
    Doug
    Mar 2005
    368
    Doug..You can only array in one direction at a time...You will need to Translate with Copy box selected and # of copies defined for the rows and then repeat for the columns.
    There may be a script written somewhere that steps thru this routine or if v20 has a Script Recorder you can create your own array script.
    The Rotate function with Copy will do a polar array.
    This is based on my experience with V21...V20 may differ.
    Bob
  1. Circular array (Design)
    By jorgehrr in forum Mastercam
    Last Post: 10-20-2012, 06:34 PM
  2. radial array around axis
    By panaceabea in forum Solidworks
    Last Post: 07-19-2007, 08:53 PM
  3. 7 Amp X 5 Mosfet Array
    By scratch_6057 in forum Open Source Controller Boards
    Last Post: 01-28-2007, 03:24 AM
  4. LED array sequencer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
  5. Linear Array
    By hay171717 in forum G-Code Programing
    Last Post: 05-28-2004, 07:18 AM
