603,392 active members*
3,184 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > Heidenhain TNC 530 Tool changer not in position DMG MORI CNC MILL
    i had a question for the gurus here i am new to heidenhain while i was learning the control i managed to do a tool change
    simple enough; it did the tool change but then i got this message alarm TC: changer not in position and it's not going away
    in my instructional manual i have two ways to clear this one is through using the soft keys but the features are not available they're all gray
    and the other is to use "MOD" and passcode "789" however it's not letting me in
    do you guys have any experience with that? i appreciate the help.
    Re: Heidenhain TNC 530 Tool changer not in position DMG MORI CNC MILL
    Quote Originally Posted by MACHINATORY View Post
    Maybe you can try this and see if it helps.
    1. Jog mode
    2. Area switchover
    3. Softkey 7 deckel maho
    4. Softkey 7 manual operation
    5. Softkey 1 tool change
    6. With the keys yellow or violet, the tool changer can be moved. If it doesn't move after poking these,
    7. Ref the axis. And all should work.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Quote Originally Posted by cncmakers001 View Post
    1. Jog mode
    2. Area switchover
    sorry what do you mean by area switchover? the buttons on the left? there is none
    there is a recover procedure for this through jog mode and softkeys but i can't figure out how to enable the tool changer it's always greyed out
    1. Jog mode
    2. Area switchover
    ok so the passcode was good it just doesn't open to another page it enables operator to access WRENCH
    from TOOL TABLE to Wrench icon then the soft keys for recovery i did something to fix it but not entirely sure what i did.
    the question though is how to avoid this? if it's not power outage ?
  1. postprocessor heidenhain TNC 530
    By clau79 in forum Mastercam
    Last Post: 05-07-2024, 03:18 PM
  2. DMG dmu 50 Heidenhain iTNC 530
    By almixk in forum Post Processors
    Last Post: 03-27-2021, 09:26 PM
  3. Replies: 0
    Last Post: 09-06-2019, 12:58 PM
  4. Check the position encoder W CNC Heidenhain iTNC 530
    By sarabanda in forum Bridgeport / Hardinge Mills
    Last Post: 03-30-2017, 12:29 PM
  5. Heidenhain TNC 530
    By Matth3w in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-18-2010, 07:16 AM
