586,103 active members*
3,420 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > What Homemade CNC for small RC aluminum parts?
Results 1 to 8 of 8
    Nov 2007
    Hi this is my first post here and am verry intrested on making a homebuilt CNC for stuff like small Aluminum parts. I have seen many home made designs and most are MDF board but I dont know if that will presicly cut aluminum.
    I would like to build a small presice machine 3 axis to cut small aluminum parts, none of the axis will have to travel more than 12".
    I do have a Mig welder and good welding skills, and many tools, I do whant to spend as little as needed probably around $500
    Any recomendations?
    Mar 2004
    1661
    Welding is an easy option but it creates tensions and misalignments.
    Scan through the build log forums and I think you'll get heaps of ideas.
    Start with
    http://www.cnczone.com/forums/forumdisplay.php?f=48
    http://www.cnczone.com/forums/forumdisplay.php?f=221
    Jun 2007
    32
    Quote Originally Posted by PAPE View Post
    Any recomendations?
    I will suggest you to contact <[email protected]> he sells his router built using aluminium for around 750$. You may want to have a look to it on youtube at [ame]http://www.youtube.com/watch?v=dGZbNNZi_Vw[/ame]. I use it and am most happy with its performance
    224
    cocodet thanks for the post and video.
    Do you machine alum parts on your machine?
    If so, what kind of part thickness, cutter type/size, depth of cut, and coolant do you use?
    tia,
    Pres
    Jun 2007
    32
    No, I do not machine aluminium. The head is a standard router and I do not think it is suitable for any metal job. I machine wood and foam to make wings for my RC planes.
    Aug 2003
    327
    I have two CNC machines and both are capable of cutting Aluminium.
    One is a SYIL X4 and the other is of my design. The homebuilt is all aluminium. You would need to make it aluminium or steel to get the rigidity required. Wood will not work.
    Here is a picture of some F16 undercarriage scissor links i made for a friend at work. He will use these in his scale Jet. A mill would be better suited to achieve your goals i think.
    Apr 2004
    5737
    Most people here are building routers intended for wood, plastic and other light materials. Mills intended for cutting metals require another level of rigidity and precision. Some people here have built them, but they tend to be people who already own or have access to larger mills and well-equipped shops already. If you're mainly interested in making small aluminum parts for your RC projects and not in experimental CNC machine-building, I'd suggest getting a Taig mill. You can get it CNC-ready and save money by setting up your own control system. (If you go that route, I'd recommend the highly-regarded G-540 from Geckodrives as the heart of it.).
    Andrew Werby
    www.computersculpture.com
  1. RFQ - small aluminum bracket
    By chris9911 in forum Employment Opportunity
    Last Post: 08-03-2007, 06:33 PM
  2. RFQ - Aluminum Parts - small job
    By F500 in forum Employment Opportunity
    Last Post: 06-08-2007, 09:30 PM
  3. How hard is it to get into CNC Machining small aluminum parts?
    By GreasyMidget in forum MetalWork Discussion
    Last Post: 10-13-2006, 03:20 AM
  4. contouring aluminum with small bit
    By corpse in forum Benchtop Machines
    Last Post: 09-14-2004, 07:11 PM
  5. Where to get cheap parts for a Homemade Router
    By teilhardo in forum DIY CNC Router Table Machines
    Last Post: 03-15-2004, 03:09 AM
