603,836 active members*
2,770 visitors online*
    Feb 2016
    12
    Exclamation hydraulic system nachi pump
    Hello
    From Guatemala, we have a problem with a ROMI CNC lathe.
    The turret (hydraulic) is not working as it should, the chuck closes/opens slowly and on the pressure gauge we only have 500 PSI (instead of 650-700)!!
    We have already cleaned and checked all the REXROTH valves, cleaned the oil filter, changed the oil, checked for leaks.... ...but the problem persists.
    We now suspect that the NACHI pump has a problem, but is there a way to confirm that the problem is the pump
    (but ??there is no particularly bad noise from the pump)
    Is it possible that the problem comes from a valve, for example, that creates a problem in the whole hydraulic circuit??
    Are there any sensors involved in the hydraulic system that can cause the problem??
    Thanks a lot!
    André
    Feb 2016
    19
    Quote Originally Posted by austenit View Post
    Hello
    Thanks a lot!
    André
    Hi how old your pump is if it is vane pump adjusted the eccentric cam By screw
    Feb 2016
    12
    Re: hydraulic system nachi pump
    Hi Narava
    Thanks for your reply - The machine is year 2000 !!!
    Do you mean the external rexroth pressure valve , or is this a way to adjust the pressure at the pump itself ??
    thanks
  1. Anyone know how to disable the hydraulic pump?
    By torinwalker in forum Hardinge Lathes
    Last Post: 05-23-2012, 03:46 PM
  2. Hydraulic pump units... two...for free
    By scadvice in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-20-2010, 11:10 PM
  3. sh50 hydraulic pump
    By chenzen666 in forum Mori Seiki Mills
    Last Post: 03-02-2010, 08:20 PM
  4. Hydraulic motor and pump?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2008, 08:53 PM
  5. Hydraulic pump and motor?
    Last Post: 07-28-2006, 06:30 PM
