588,503 active members*
4,980 visitors online*
    Jun 2004
    19
    Choosing Steppers
    I am currently looking for steppers to suit a 3"x10" cnc lathe I am building. I have found a pair in a old IBM dot matrix printer. The specs are 2.46V, 1.82A, 1.8 deg/step. They are fairly large in diameter at about 3". Anyway, I am just wanting to know what is involved in making a decision on what size steppers to use? Would these sized steppers be useful in a small lathe such as the one I am building? Would they be suitable as a retrofit for the 7x12 type machines?
    Thank you
    Ben
    Jun 2004
    55
    Can't help you with your question, as 'm new here, but I would ask you if you have found the wiring diagram of those motors, as I've found a couple too in an old IBM printer, and I would like to start playing a bit with CNC.
    Unfortunally I've not been able to find any specs for those motors.
    Wish you can elp. and sorry for my bad english ( I'm from Italy btw )
    Cheers
    Pigi
    Jun 2004
    19
    No I don't have diagrams yet, they appear to be a proprietary type stepper, ie no diagrams will be available unless IBM release them as part of the tech service manual. The steppers are actually Sanyo Step-Sync and so I would assume/hope that Sanyo kept wire colours on their 6 wire steppers the same across the range.
    Once I have a controller built I can play some more with them and hopefully let you know!
    Regards
    2139
    That is a small lathe. I would think those would be great motors for the task.
    Eric
    I wish it wouldn't crash.
  1. Help with choosing steppers motors
    By Biggermens in forum Stepper Motors / Drives
    Last Post: 03-28-2005, 08:03 PM
  2. Help with choosing steppers motors
    Last Post: 10-22-2004, 04:23 AM
  3. Just found some steppers!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-15-2004, 01:32 AM
  4. steppers and current
    By ullbergm in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:24 PM
