Re: Leadshine L7 servo drive error
Originally Posted by
Pnai
Hello all.
This is my first post in this forum , I don't know if this is the right section to post.
I'm running a Large Format UV Print and I'm have problem with the Double Y's axis.( Position Error ).
I search for the the L7 drive to Log test and I followed all the steps , When I press run it display error , although before I run the log test it gives ready ( r 0 ).
I will write the steps I make for Log test if it help:
(SET): d015P
(MODE): PR000
(MODE): RFJ0g
(SET): Jog-
(?): error
I hope someone can help me .
Thanks a lot
Make sure all cables and connections are secure.
Sometimes a loose wire can cause a position error.
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
