603,959 active members*
4,836 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Narrowing Guitar Fretboard with Frets Installed?
Hybrid View
speakerbuilder Narrowing Guitar Fretboard... 11-16-2024, 02:05 AM
difalkner Re: Narrowing Guitar... 11-16-2024, 03:19 AM
    May 2015
    What are the chances I can get away with machining the sides of an ebony fretboard without removing the frets? I want to reduce the width by 0.05” on each side.
    I'm thinking maybe a 4-flute downcut mill could work if I take very shallow passes. And if this could work, carbide or high-speed steel for the mill?
    Nov 2014
    708
    Re: Narrowing Guitar Fretboard with Frets Installed?
    Depends on how close the frets are to the edge, are they blind or open slotted, is the fretboard bound, how good are you at measuring and setting up your machinery, etc.? I'd probably just use a plane or sanding block if it were mine.
    Got any photos of the fretboard?
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
