603,377 active members*
3,216 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Minimum/Maximum Segment Distance/Length in Post
    Nov 2013
    47
    Post Minimum/Maximum Segment Distance/Length in Post
    Hi, I was hoping someone here may know if there is a setting in the post processor for maximum distance between points output. I ask because my current mill setting runs MUCH smoother using a spline interpolation mode, but this goes awry when you have a curve with many points connected to a straight run with very few. If I increase the density of the toolpath points on these straight runs, then all should be well. Many thanks! -O
    May 2006
    367
    Re: Minimum/Maximum Segment Distance/Length in Post
    There is in tool settings I believe.
    But... I've found it better to have a better drawing. What I do is rebuild each complicated line in Rhino for more consistent point positions and quantity of points. A lot of times if you have 100 point line... you can rebuild to around 30 points and deviation will only be .001" or less
    Nov 2013
    47
    Hi. Thanks for your input. For clarity, are you suggesting I rebuild the straight segments in the toolpath to have many more segments and this may increase the points being output in the post processing? That'd be great as I don't have this problem too often. Are far as settings in the tool, would this be the tool tolerance? I have my tolerances pretty jacked up as it is already, but if it is a straight line (or curve rather represented by 4 control points) would it not still be output essentially as endpoints? I'm going to model up some dummy geometry and see what happens. Thanks again for your insight and time! -O
    May 2006
    367
    I missed you were talking about straight lines... but either way... the drawing itself makes a huge difference. Experiment and it will become obvious quick which your machine likes
  1. Replies: 4
    Last Post: 05-29-2015, 05:15 PM
  2. Star SR32 - How to set up part length and safety distance?
    By VSO in forum CNC Swiss Screw Machines
    Last Post: 06-11-2014, 04:39 AM
  3. Heidenhain 151 - Minimum and Maximum Arcs
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2012, 11:50 PM
  4. maximum available length for 1.6mm drill bit
    By LuckyStrike in forum CNC Tooling
    Last Post: 06-27-2008, 04:50 PM
