I am milling a 3D design in a foam block. Max depth of cut: ~50mm.
When moving in X+ direction, the tool is doing climb milling and it is cutting smoothly.
When moving in X- direction, the tool is doing conventional milling and there seems to be some vibrations.
Is there any setting in fusion, to use faster feedrate in X+ direction and slower feedrate in X- direction.
