Hi.
A mistake can ram the touche probe against the workpiece.
And seriously damage the touche probe.
What if you use a piece of plastic foam as workpiece ?
With aluminiumfoil around the foam.
Maybe first tape some gaffertape against the backside of the aluminiumfoil to make it a bit stronger.
If the touch probe or cutter then rams against the foam workpiece there is less chance of damage.
Vroemm.
