603,900 active members*
2,284 visitors online*
    Sep 2004
    209
    Lightbulb Enable shift key for Fanuc 6M.
    I've been using macros on my Fanuc 6M for a while, but I haven't been able to access any of the extra characters ("[", "]", "#", "=", etc.) to edit programs on the machine. Every time I wanted to edit a program that contained macro characters, I had to edit it on the PC and send it through the RS-232 again. I knew that the ABS/INC key is supposed to double as the shift key, but it didn't work.
    That all changed this morning when I found a parameter in 6M operator's manual that enables the shift key. It's called MSFT, which is parameter 0308, bit 6 (second bit from the left or X1XXXXXX). It works like a charm and I think I only found it because I was looking for something else.
    Just keep in mind that the shift key still toggles between ABS and INC every time it is pressed.
    Chris Kirchen
    Sep 2005
    767
    That key should toggle between ABS and INC only when you're in MDI or JOG mode. When you're in EDIT mode, the key should function like a shift key. On later 6Ms, the ABS/INC key changes the cursur at the bottom of the screen from a "-" to a "^". Only the next key you press should be "shifted".
    The ABS/INC status shown on the CRT only applies to MDI moves. In your program, the G90/G91 state is used instead. On many 6Ms there is another panel switch called "ABS" or "Manual Absolute". When this switch is NOT on, you're in INCREMENTAL mode, and any jog or handle motions you make also shift the zero point on your program. If the switch is on, then your zero point in the program is not shifted by jogging. Many a crash can be attributed to that switch. I know a lot of people who get behind the panel and jumper that switch into the "permanently on" position.
    May 2003
    70
    My 6m has parm 308 set at 01000000 and the shift key
    (abs/inc) still doesn't do anything. Any suggestions?
    May 2003
    70
    Let me rephrase that, the abs/inc key changes the format as intended, but in any mode it doesn't preform a shift function....
  1. Grid Shift
    By scuba in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2013, 02:10 PM
  2. Shift knobs
    By hot knobs in forum Trade Shows / Webinars / Other Events
    Last Post: 08-12-2007, 01:34 PM
  3. Spindle enable alarm Fanuc OTB
    By hien100881 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2007, 08:29 AM
  4. Datum Shift with TNC530
    By Bubbles in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-20-2006, 11:23 PM
  5. Anyone need help on 3rd shift??
    By AMCjeepCJ in forum Milltronics
    Last Post: 12-22-2005, 08:34 AM
