603,923 active members*
3,192 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > 2004 Multicam 3000 Teknic SST 1500-561 issues
Results 1 to 7 of 7
Hybrid View
Canadaguy 2004 Multicam 3000 Teknic SST... 01-31-2025, 08:57 PM
joeavaerage Re: 2004 Multicam 3000 Teknic... 02-01-2025, 04:01 AM
Canadaguy [QUOTE=joeavaerage;2607818]Hi,... 02-01-2025, 04:08 AM
joeavaerage Re: 2004 Multicam 3000 Teknic... 02-01-2025, 07:59 PM
MCPservice Re: 2004 Multicam 3000 Teknic... 02-03-2025, 03:47 AM
Canadaguy Re: 2004 Multicam 3000 Teknic... 02-03-2025, 05:38 AM
MCPservice Re: 2004 Multicam 3000 Teknic... 02-04-2025, 12:36 AM
    We have a 2004 Multicam 3000 USA machine with 4 Teknic 1500-561 servo drives! The z drive was running rather slow and recently has stopped worked and is showing a fault of 11 blinks (see trouble code in attachment)on the drivers!
    We have the M24 board and would have to pay Multicam $3700 to come out and re load the drive with the proper parameters which is absolutely crazy!
    I have orders a USB 4 strand cable and the molex connector and have the wiring diagram!
    I’m wondering if anyone has fixed this issue on their own successfully and if anyone has the correct perameters for the z drive?
    The machine is in great shape for its age and everything works except for the z driver but we are looking at upgrading everything and parting out the 3 remaining driver along with the two x motors, y motor, z motor, touch off probe, pendant, M24 board, transformer ect if anyone is interested! Locations Calgary Alberta Canada
    Also has anyone done an upgrade with DMM tech or Teknic clear path on this size of CNC? What AC service drives did you go with?
    Attached Thumbnails Attached Thumbnails IMG_3406.jpg   IMG_3411.jpg   IMG_3361.jpg   IMG_3368.jpg
    Nov 2013
    5409
    Re: 2004 Multicam 3000 Teknic SST 1500-561 issues
    If they guarantee its going to work....is it that crazy? I presume you use this machine for a business? With it out of action are you losing money?
    If there are other solutions like changing servos and/or drives....how much is that going to cost?. Could be that 'I saved having to pay Multicam $3700 by adopting a solution that cost me only $5000....bargain'.
    Craig
    Craig
    - - - Updated - - -
    Sorry I should have mentioned that they will not offer any type of warranty or guarantee since they are discontinued/ obsolete!
    If we do a full upgrade including servos and motion control we are looking at about 10k, but that would mean everything is new and we would have tech support through whatever manufacturer we choose to go through - masso g3 or centroid acorn and clear path or DMM tech!
    So I’m more inclined to spend 10k for a guarantee than $3700 for a chance!
    Also this is a 30 second fix with the cable/software and proper parameters - we are happy to pay but they want to fly in a tech to do it!
    Nov 2013
    5409
    if you have no certainty that the $3700 is actually going to work, then yes, I agree I'd be reluctant to chance it myself.
    The more I pay for something the greater certainty I need that the item purchased or service provided matches the requirement. $3700 is definitely in that category.
    Craig
    Jun 2010
    480
    Send em your email I have those files
    You will need the programming cable and software
    Your inbox is full - can you private message me the parameters for all the drives - I have turned on private messaging! Thank you!
    Jun 2010
    480
    mphelps@mcpservice.com[
    QUOTE=Canadaguy;2607938]Your inbox is full - can you private message me the parameters for all the drives - I have turned on private messaging! Thank you![/QUOTE]
  1. Multicam 3000 2005 machine Teknic SST-1500-561
    By Verucktjim in forum Multicam Machines
    Last Post: 07-21-2023, 07:12 PM
  2. Teknic SST 1500 561 Servo drive
    By Electrobyron in forum Servo Motors / Drives
    Last Post: 05-16-2023, 06:05 PM
  3. Anyone Using Teknic SST-1500 Servo Control?
    By CJL5585 in forum Servo Motors / Drives
    Last Post: 08-04-2022, 07:17 PM
  4. Anybody have a Teknic SST-1500-UCX for sale?
    By minty_jones in forum Servo Motors / Drives
    Last Post: 06-21-2011, 05:20 PM
  5. any one have or seen Teknic SST-1500 servo amplifier
    By chrisw765 in forum Servo Motors / Drives
    Last Post: 09-17-2009, 03:23 AM
