603,850 active members*
4,476 visitors online*
    reduce z height travel at start of code
    I have just purchased a Genmitsu Vice for my 3020 plus, but now i am struggling with Z height, at the start of every program the head moves up and hits the Z limit switch, i need to reduce the amount of vertical travel at the start of the code
    i can google it, but was hoping someone of here would help
    Thanks for any help
    Jul 2018
    6841
    Re: reduce z height travel at start of code
    Hi -The first move is not a programmed move, it is a move by the controller. Its either moving to the set safe height or to a clearance height. Depends on what CAD and CAM you are using. So what CAD CAM are u using? Peter
  1. Tool Travel Height
    By TrinityXYZ in forum CNC Tooling
    Last Post: 06-17-2022, 03:50 PM
  2. Fadal 6535 Z travel height
    By EliteCustoms in forum Fadal
    Last Post: 07-21-2021, 12:25 PM
  3. Relative safe travel height and potentially other suggestions
    By jm82792 in forum Uncategorised CAM Discussion
    Last Post: 02-11-2012, 08:54 PM
  4. Changing rapid travel height at the machine
    By Bigrhamr in forum DynaTorch
    Last Post: 08-06-2010, 06:59 AM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
