603,366 active members*
3,654 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Retract Height Limits
Results 1 to 8 of 8
    Hi, I just started using MadCAM. my problem is - that the retract height is going above the stock box too much, My CNC has a very limited Z depth, and it is going about 30mm above the stock, which I set so it doesn't go across the unmachined areas when it moves to the next stage. Does the program have an option for a higher retract from a machining step and not go above a certain height compared to the stock box also?
    My machine is an Oozenest Workbee Z1, I am using a 600mmx600mmx60mm foam board for a guitar cut prototype (I heard I could lower the baseboard to below the frame, although I really would like getting this done in the software.)
    May 2006
    367
    Re: Retract Height Limits
    Safe Z. Unchecked that box in settings. Settings is in toolbar gear icon.
    No luck, I recalculated it after changing the settings and it was exactly the same. Anything lower than a 35mm safe clearance and it cuts through the stock material harshly, so I can not reduce it either.
    May 2006
    367
    Not there. Click on gear in Madcam toolbar. There is a box safe Z.
    Also, when post processing you type in XYZ. I have my model in correct location in CAD... type 0,0, then put my Z height a safe number so it won't gouge part in retracts and moves. This Z value isn't the 0 of part... but distance above part for safe movements
    I recalculated it on both. Safe clearance above the model box does not change it to adding or removing a safe clearance above the model box.
    May 2006
    367
    Check box, view your code... then uncheck, view code. It should change.
    The post-processed code showed z65 after both saves. Do the changes show in the GUI?
    Fixed!
    I thought that the options menu was for restricting it to the box or not, it was for retracting to the top instead of a distance from the drill down.
    I set the safe clearance to 1mm and 'set the safe clearance above the model box' setting on, and now I have the retract going 1mm above the box every time.
    Thank you for nudging me in the right direction.
  1. Tool Change Retract Z Height Issue
    By NismoGT in forum Fadal
    Last Post: 08-13-2018, 03:58 PM
  2. Replies: 0
    Last Post: 01-16-2014, 06:12 PM
  3. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  4. Changing Retract height for ever.
    By eddie3000 in forum Uncategorised CAM Discussion
    Last Post: 07-05-2012, 11:32 AM
  5. Retract Height
    By Sanghera in forum SheetCam
    Last Post: 05-30-2005, 05:52 AM
