603,370 active members*
3,352 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 7075-T6 aluminum machining and dimensional distortions
    Residual stresses after machining is the problem for reaching to close tolerances on this material. I'm eagerly listening to your suggestions for making accurate parts. Any heat treatment for stress relief should be done?
    Mar 2015
    53
    Re: 7075-T6 aluminum machining and dimensional distortions
    Back years ago, I worked at Boeing. We would rough the part +0.100" then fly cut the indexing surfaces flat.
    Next, we machined to +0.030" and then fly cut the mounting surfaces.
    Finally the net cuts were completed and the top and bottom was machined net.
    The shop I worked in was Flight Test support and we primarily did one off parts.
    7075 does tend to warp. Lots of coolant is your friend.
    Cheers,
    Dave
    What kind of fixtures do you recommend for minimal stress? Toe clamp?
  1. Dimensional Accuracy - Aluminum vs. Titanium
    By CNCMaryland in forum Milling
    Last Post: 01-26-2020, 01:13 AM
  2. Replies: 6
    Last Post: 11-03-2017, 04:28 PM
  3. 7075 Aluminum
    By TampaCNC in forum Mastercam
    Last Post: 02-01-2017, 09:49 PM
  4. researching dimensional machining errors..
    By SoCalPlaneDoc in forum Tormach PathPilot™
    Last Post: 08-19-2016, 08:43 PM
  5. 7075 Aluminum
    By mtechserv in forum Moldmaking
    Last Post: 03-28-2005, 05:27 AM
