603,924 active members*
3,334 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC 25 not booting
Results 1 to 15 of 15
    Mar 2025
    11
    Hoping there is someone left still alive, that has some knowledge of the boards used in the control of my Hurco BMC25 with ultimaxIII Max32/dsp.
    This week it refuses to boot ocasionally only with a cursor in the bottom left of text screen. Wonder if it needs new dallas chip? or if someone knows where to start looking would be a great help? and no!! Hurco service can not help they say its too old, bit like me I guess!
    Re: Hurco BMC 25 not booting
    Quote Originally Posted by ziggyd View Post
    Many older CNCs use a Dallas DS12887 or similar chip that contains both the
    Real-Time Clock (RTC) and non-volatile memory for BIOS settings.
    If this chip has failed (common after decades of use), the system may fail to boot properly.
    Check if the date/time resets when the machine does boot. If it does, the chip is likely dead.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Feb 2006
    191
    Also on these old machines, It never hurts to step back and using the static band on your hand
    to unplug and then re-plug in all the boards and connections - vibration and time takes it toll
    Mar 2025
    11
    I have removed and cleaned all boards and contacts, used contact cleaner on all plugs etc. tried removing some boards to get to a minimum set up but nothing gets on screen? Having nothing much to go on yet, leaves me wondering if I should change this dallas chip for a new one, But I can find no details or instructions on how to enter the Bios stup on this Hurco with 486 cpu board,or to get to the settings, will all the required info be lost?? (Thats if it is infact the rtc stopping it booting?) Has anyone had to replace the dallas rtc chip,and gone through the initial setup on a similar machine? Is there anyone in the uk who can check or repair Hurco boards?
    Feb 2006
    191
    Well, I missed the fact that it is Ultimax III and not Ultimax II which is what I have .
    So my words may not apply, but the Dallas chips provide power for memory use and the Batteries in them die
    One of the repairs is to have batteries added to your board so the Dallas chips are bypassed ( sort of) for the power needs ( not mem )
    Does your memory board have batteries like this- ?
    If it does not, then putting these special batteries in is easier than replacing the Dallas chips IMHO
    The batteries are none rechargeable ( I think 3.6 V) and I can find out the number if you need it
    Mar 2025
    11
    The 486 board is quite different, it only has one dallas chip, no other batteries, I am concerned that the bios has possibly been lost , does the Dallas on the cpu board actually hold the bios setup with boot order,etc. and HD config table? If I replace the Dallas rtc chip with a new one, how do I get into the bios config to put things back as it was? what would I need?
    Feb 2006
    191
    Ziggyd
    I don't think so. I believe it it supplies voltage to the board AND directs the storage of memory in the adjacent memory chips . Folks have replaced the Dallas chip and did not incurr Bios problems to the best of my knowledge and I have followed this board for 20 years
    If you look at my picture you will see a string of chips with pasted labels . On my KM3 there are maybe 12 such chips in line and
    note that they say the version of Ultimax on them . They are the chips that match the what you have in your machine..ie the Ultimax program .. But I do not know if that includes the Bios ?
    There is help in the UK. We had a wonderful guy who helped people . I believe he is a retired Hurco tech Service (???) and his name is Bloke . try a search on this forum
    Good luck
    Rich
    Mar 2025
    11
    Thanks for reply, I have been in touch with" Bloke" hope he has time to help, and look into my hurco problem, not many folk left who worked on these machines,
    Mar 2025
    11
    Don't seem to be getting any nearer finding out how to access the bios on our Hurco , the cpu card is a radi sys corporation 486 board, the machine is with Ultimax 3 and max 32/DSP I was hoping someone could explain to me if its possible to gain access to the bios , and check all is OK
    Feb 2006
    191
    Ziggyd. I posted about 6 postings back on this Forum , a note about Midwest CNC
    I know it's a international call, but they have been helpful to others, maybe they can answer the Bios question
    Rich
    Mar 2025
    11
    Rich, thanks for reply, I have been in contact with Midwest cnc,they need a bit more info, but I will be back in touch with them soon as possible. lets hope I can make some progress?
    Mar 2025
    11
    Unfortunately Midwest cnc Have no idea how to acess the 486 bios on my machine,... well that was their reply? but credit to them they did respond quickly.
    Mar 2025
    11
    It been almost impossible trying to obtain infor on this Hurco BMC25 with Ultimax 3 , and max 32/dsp upgrades, Is there anyone anywhere who has any technical details of the system , the board cofigurations , jumper settings, test points, or anything related to repairing and testing this system? even what the on board LEDS mean on the cpu or the personality board. It would be great to just narrow things down, I can't just replace things randomly. or spend money on parts, if the part is OK
    Although replacing the machine seems to be the only resolve!
    I have read others have been in a similar situation ? Did Anyone find a current service engineer, or any repair info, relative to this actual Hurco machine and control sytem?
    Feb 2006
    191
    ziggyd, there is another resource that I have not mentioned I beliive, and they have a very good reputation
    https://www.machinetools.com/en/comp...martin-cnc-inc
    He also worked for Hurco and His credentials say BMC service - worth a shot i think
    Shane Martin 352-326-0047
    Florida
    Rich
    Feb 2006
    191
    Ziggyd- here is another possible resource
    Download Masters, Software and Post Processors | Accurate Machine Tool Svc, Inc
    And they do free help to BMC owners
    Rich
  1. Replies: 1
    Last Post: 02-15-2020, 05:17 AM
  2. Hurco VMX24 control kit Won't booting
    By KangMus in forum Milling
    Last Post: 02-14-2020, 07:55 AM
  3. HURCO BMC 25
    By Mysak in forum HURCO
    Last Post: 09-23-2013, 11:47 PM
  4. Hurco BMC 24
    By Hurco1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2012, 12:04 PM
  5. Hurco Hawk km5p mill servos not booting
    By thespindoc in forum HURCO
    Last Post: 05-23-2010, 12:47 AM
