603,340 active members*
3,628 visitors online*
    Aug 2023
    Angry Spindle will not start!
    Hello,
    I am so sorry in advance if this post is in the wrong thread!
    I am having trouble getting the spindle of my Laguna Creator CNC to start up. I have already made a ticket with them, but I know they take up to weeks to respond. Thought it doesn't hurt to make a post here to see if anyone can shed some light to this issue.
    The machine has never went through this problem before and has always ran great up until this point. The VFD currently just displays "Stop".. It is an MS300 from Delta. The reset button on the VFD does not do anything. Is there anyway I can force reset it? I have already bled my eyes trying to find the answer in the VFD manual, but with my untrained observation, I don't think I am even capable of finding the answer there.
    Any help at this point is greatly appreciated!
    Thanks.
    Nov 2017
    Re: Spindle will not start!
    we have this issue with the SS4. any fix?
    Nov 2011
    478
    If the spindle on your Laguna Creator CNC (paired with a Delta MS300 VFD) won’t start and the VFD screen displays "Stop," try these quick troubleshooting steps:
    Power cycle the VFD and CNC.
    Check the emergency stop button and limit switches for activation.
    Test the VFD manually (disconnect CNC control wires and attempt to start the spindle directly from the VFD keypad to rule out signal issues).
    Look for hidden error codes on the VFD (e.g., E.OC for overcurrent or E.UV for undervoltage).
    Inspect spindle cables and power connections for damage or loose wiring.
    If the issue persists, the problem may be incorrect VFD parameters (try a factory reset) or hardware failure (e.g., blown fuse). In such cases, contact Laguna support or a professional technician for further diagnosis.
    https://www.elephant-cnc.com/
    Whatsapp/mobile: +86-15064026772
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Deckel Maho DMG 635V Spindle in not locking Well, Restart when spindle start rotation
    By farshadjs in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-07-2023, 04:27 PM
  2. Alarm on Spindle Start/Spindle Orentation
    By DanielsSpeed in forum Milltronics
    Last Post: 10-10-2020, 06:45 PM
  3. Spindle Won't Reach Speed after Brake On while Spindle Start
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2014, 04:59 AM
  4. Replies: 1
    Last Post: 05-03-2013, 12:42 AM
  5. spindle start-up
    By poster in forum Milltronics
    Last Post: 08-30-2011, 12:34 PM
