603,795 active members*
2,941 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > 3D modelling in the real world
    May 2007
    47
    Hi
    I have been working in 3D on the computer for years and have just started to try and bring 3D models into the real world through CNC. From a practical point of view if I want to glue a round mdf peg into a round mdf hole do I make the peg and the hole exactly the same size or do I allow a mm or two for the glue?
    Thanks Ken
    Nov 2007
    8
    Hello ksealey, I too have been doing 3D modeling for many years and I do woodworking as well. I can tell you from experience that you will need to leave a small amount of room for 'squeeze-out'. Otherwise the glue in the hole will have no way to escape past the peg and bond the two pieces together, and you will have a very difficult time getting the peg into the hole.
    I don't know if I would leave more than one millimeter of clearance, especially if you are doing something that has to be precise. I would do a test run if that is the case just to see. Hope this helps.
    37
    A small V down the side of the peg will allow the glue to excape.
  1. use of G10 in the real world.
    By bookwurm99 in forum G-Code Programing
    Last Post: 12-10-2007, 09:43 PM
  2. Learning 3D modelling
    By randyf1965 in forum Uncategorised CAD Discussion
    Last Post: 01-12-2006, 01:27 PM
  3. Mill Drill Real World CNC Feed Rate
    By wmgeorge in forum Benchtop Machines
    Last Post: 09-28-2005, 08:39 PM
  4. Any real world experience with Camsoft & Steppers
    By mbam in forum CamSoft Products
    Last Post: 06-23-2004, 04:59 PM
  5. guitar neck modelling....
    By anoel in forum Rhino 3D
    Last Post: 04-17-2004, 05:33 AM
