603,836 active members*
2,718 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Help needed with SolidCAM post processor editing for tool change logic
    Apr 2025
    I'm working on customizing a SolidCAM post processor and I'm running into an issue with the tool change logic. Currently, the post outputs a tool change (Txx M6) even when the same tool is used across multiple operations. I'd like to suppress the tool change command unless the tool number actually changes.
    I'm using SolidCAM 2023 with a Fanuc-based machine, and editing the .mac and .gpp files directly. I've tried using the tool_change_required condition, but it doesn't seem to behave as expected — it's either always true, or never triggers depending on where I place it in the post.
    Has anyone dealt with this before? Any guidance on the correct logic or post variables I should check for conditional tool changes would be really appreciated.
    Apr 2025
    Re: Help needed with SolidCAM post processor editing for tool change logic
    No one knows how to solve this. I'm really stuck.
