603,316 active members*
2,685 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli 504 Author, Axis not moving
    hello i have a morbidelli 504 author
    the thing is, i cant calibrate or move any axis
    when i try to manually move any axis, i hear like a contractor sound at the router ( not in the controller ) then i get an alarm - (the axis i selected) axis follow up error, the same goes when i try to calibrate it i get that alarm
    2 days ago the machine was working perfectly fine, today when i tried to work with it i got this error
    any clue?
    Re: Morbidelli 504 Author, Axis not moving
    Quote Originally Posted by monavdyliks View Post
    any clue?
    Could be below reasons:
    Drive not delivering power to the motor
    Motor mechanically jammed
    Encoder signal missing or faulty
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    If i push any axis by hand, the position updated on the screen
    The servo drives are never being enabled
    Motors are fine
  1. Disconnecting C Axis or A Axis on a Morbidelli Author 504
    By KCF in forum Questions or Problems
    Last Post: 08-21-2018, 10:18 AM
  2. Morbidelli Author 504 - Xilog Plus
    By JaimeCNC in forum CNC Machining Centers
    Last Post: 04-16-2016, 12:29 PM
  3. Any Morbidelli specialist here??? Need help on a 504 author
    By jpcnc in forum Uncategorised WoodWorking Machines
    Last Post: 03-17-2016, 09:22 AM
  4. HELP TO RESET A MORBIDELLI AUTHOR 504
    By alfonsonog in forum USA Club House
    Last Post: 01-30-2015, 03:04 AM
  5. morbidelli author 504
    By msahin2012 in forum Commercial CNC Wood Routers
    Last Post: 05-19-2009, 01:06 PM
