603,415 active members*
2,765 visitors online*
IndustryArena Forum > CAM Software > CamBam > Where can I access M6 instruction in CamBam
    Nov 2014
    10
    I want to be able to change the M6 Instruction to M3. I have been over this like a nasty rash and I cannot find where it is hiding.
    Secondly my CamBam is producing Arc data to 16 decimal places i.e. 2.0133627727628013 is there a way to limit this to 5 or 6 places. I'm convinces this is what is making my UGS take a wobble.
    Jan 2010
    53
    Re: Where can I access M6 instruction in CamBam
    Look at the documentation under Postprocessor
    https://cambamcnc.com/doc/1.0/cam/post-processor.html
    Options - Number Format
    A hash character (#) denotes an optional digit place holder and a 0 character denotes a digit that is always displayed, adding padding zeros if required.
    My setting is 0.00##
    This means that two decimal places are always output and two more only when they are needed.
    If you always want to output 6 decimal places you write 0.000000. All decimal places that are not used are output as 0, but they are always output.
    If you write 0.00####, two decimal places are always output, but up to 6 decimal places are output if necessary
    M6 to M3
    M3 is usually the specification for clockwise spindle.
    The M6 is in the postprocessor in the tool change macro.
    You can open the macro under tool change and enter M3 instead of M6.
    The postprocessor must then be saved. To do this, you should use your own name so as not to lose the original postprocessor.
    It is very important that you not only change the M6 to M3 but also change the command for spindle clockwise from M3 to the command you want.
    Otherwise there will be a conflict between the two commands
    Nov 2014
    10
    That's Magic ! Thank you so much. Cured my nagging M6 issues. Having said that I still don't seem to be to reduce the number of trailing decimal places in my settings. (I'm probably in the wrong place !)
    When I view my settings files I still have
    Am I in the wrong place? Is there a global setting for all coordinates ?
    Jun 2013
    28
    You seem averse to reading to the manual, Ralf posted a link to information regarding those settings.
    Jan 2010
    53
    Sorry, I misunderstood you.
    The number format in the postprocessor only controls how many decimal places are generated in the G-code output.
    This has no influence on the decimal places displayed in the program.
    Due to the limitations of current computer technology, we expect an accuracy of up to 15 digits in calculations, in a range of ±1020 to ±10-20. This limitation is found in all modern CAD products.
    Cambam calculates this precisely and also displays these decimal places.
    Otherwise, several calculations would result in inaccuracies when rounding up and down, which would quickly exceed the precision of a machine.
    I know of no way to reduce the display of decimal places in CamBam.
  1. Replies: 2
    Last Post: 02-24-2015, 03:26 AM
  2. Variable go-to instruction
    By swatcher in forum Fanuc
    Last Post: 10-27-2010, 08:52 PM
  3. Looking for some instruction
    By nosplinters in forum Education - Teachers and Students Hangout
    Last Post: 07-13-2009, 09:44 AM
  4. video or cd instruction
    By logos in forum Fadal
    Last Post: 05-20-2006, 02:40 PM
