587,306 active members*
3,888 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > plastic blocks for mould making
    Apr 2007
    17
    I need to make a 2 part mould in which to pour molten wax into for casting.
    I need blocks of plastic around 150mm x 200mm x 60mm, does anyone know of a UK supplier? or even the name of a product?
    The plastic I need to use just needs to be able to be cut cleanly in my cnc machine with a ball nose cutter and be suitable for holding molten wax.
    So far I have made test moulds using wood (oak) but I need something that will release the solidified wax more cleanly.
    Jan 2007
    355
    Hi David,
    I think that Delrin would be a good choice for what you have in mind.
    It machines very nicely, and should easily handle molten wax.
    Check out Ebay for some great deals on surplus Delrin blocks and rods.
    You can probably find it locally from a metals and plastics supplier, but the cost will be prohibitive.
    Another option would be a two-part polyurethane casting resin. This can be found at local hobby shops, and of course, Ebay.
  1. Milling Black plastic blocks
    By joguy in forum RFQ Feedback
    Last Post: 11-20-2008, 07:57 PM
  2. Building blocks for mould/plug construction?
    By Splint in forum Composites, Exotic Metals etc
    Last Post: 01-23-2008, 04:33 PM
  3. Suggest software/machines for making tyre mould
    By Janardhan in forum Moldmaking
    Last Post: 12-07-2007, 01:34 PM
  4. Alu. mould making end mill question?
    By GalaticDan in forum Moldmaking
    Last Post: 11-30-2006, 07:42 AM
  5. WHere to buy Plastic Blocks??
    By carguy327 in forum Glass, Plastic and Stone
    Last Post: 08-04-2006, 02:30 AM
