Originally Posted by
MrWild
I know there are the A?B encoders and they can be used in quatrature. There are A+/A-, B+/B- encoders that can also be done in quatrature.
Incremental encoders are usually all quadrature, they then can be used in native count (x1) or double (x2) or four times resolution (x4) they are all quadrature to begin with, it has nothing to do with x4 count (or the x2 for that matter).
They all usually detect a etched grating and photo/emitter/detector method using the moiré effect to enlarge the 'shutter' effect, and this results initially in a sine/cosine signals 90° apart, hence quadrature signal.
Absolute usually required a completley different interface as they out put a various multi bit wide data, some 8 bit, 12 bit etc. Also the code bit code can be in different forms, binary, gray code etc.
I found buying encoders off of ebay a crap-shoot, unless you know what you are buying and they should be new or NOS, if used, you usually end up with some duds.
Al.
Albert E.
