603,392 active members*
3,242 visitors online*
    Mar 2004
    11
    pick off on citizen f12
    I picked up a old citizen f12. Can someone tell me how the pick off works. Does it rotate? Can it make a part with no cutoff tit?
    Thanks for the help.
    Oct 2007
    88
    if you have win cnc, you can learn a lot about that for your machine. you might try starting both spindles in the same direction and use
    G750- Pick up part with sub spindle mode. First G750 will queue with
    $1 and $2, then X1 will move to return position(all the way up
    safe), or optionally you can leave X1 at it's currant position
    by using "G750Q1" in $1. Z1 is not moved. Next the sub spindle
    will rapid in front of the part and automatically feed onto the
    correct pick up position by using information from the
    machining data page. If the part length is 2.0" and the back
    spindle chuck position is .75" then Z2 will feed on 1.25" from
    the end of the part. It is a good idea to have the cut-off tool
    in place and ready, then command G750.
    $1 $2
    G750(Q1) G750 W.05 F80.
    Q1= Only in $1. Q1 will not move X1 to a safe position. If
    no Q1 then X1 moves to return position.
    W.05= Rapid the sub spindle .05 away from the front of the part.
    F80.= Feed rate to move to chucking position.
    $1 $2
    G700 G700
    T1200
    G0X1.3Z-1.5T12
    !L1 !L1
    M3S1=2500M24S2=2500 M72
    G750Q1 G750W.05F80.
    !L2 M15
    G1X-.1F.002 M73
    M5M25 !L2
    !L3 !L3
    G53Z4.9213(125.mm)
    Oct 2007
    88
    that didn't post to well, so try looking at win cnc program
  1. Citizen CAV barfeeders
    By EdgeCrusher in forum CITIZEN Machines
    Last Post: 09-26-2017, 12:51 PM
  2. Citizen tool pre-setter
    By yoopertool in forum CNC Swiss Screw Machines
    Last Post: 09-18-2007, 12:54 PM
  3. DPRNT on a Citizen with a L25/32 CONTROL
    By mistux in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-20-2007, 09:26 PM
  4. How to operate a Citizen FL-42
    By Twistr in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2006, 12:23 AM
  5. Milling with a Citizen C16
    By Koalas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2005, 08:22 AM
