588,017 active members*
8,829 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Possible to increase spindle speed?
Results 1 to 13 of 13
    Jun 2006
    126
    I've been thinking,
    Is it possible to increase spindle speed to say 6000 RPM or so?
    As not too lose too much low end torque maybe put VFD in there with bit larger power motor, etc. Or is it not even worth bothering due to mill spindle limitation?
    Things I am machining (aluminum/copper most of time) can really use some ramp up on speed of cutting by increasing spindle speed is what I am seeing...
    Sep 2006
    203
    Easiest way is to put an air spindle in your spindle now. Have it turned on and off with the G-Code controlled relays.
    Air spindles come in a huge range of speeds. Up to 113k rpm. The one I like is the Macro Technologies unit.
    Their unit is 30k rpm.
    Direction, Commitment, Follow Through
    Jan 2007
    93
    What do those air spindles typically cost?
    Oct 2006
    669
    Boy I hope you have a HUGE air compressor and don't mind listening to it pound all damn day...those air spindles use ridiculous volumes of air. Look for a Lyndex R8 spindle speeder...they typically can run up to 25,000 rpms. They fit in your R8 taper and have a planetary gearing system like an automatic transmission that multiplies whatever spindle speed you have by a factor of 4...
    Jun 2006
    126
    What do you mean HUGE? I am already using abtou 15 SCFM for my cold air gun? :P Is it something like 30SCFM?
    Jan 2007
    93
    I don't think that I'd have much luck with a spindle speeder, My spindles runnout is .003". I need to do something about that but the head (or column) is out of tram by .007 on the Y so I'm guessing it's going to be one thing at a time.
    Oct 2006
    669
    Quote Originally Posted by jinu117 View Post
    An air driven spindle typically consumes 50-80 cfm.
    Jun 2006
    126
    Yikes...
    Thackman, how did you check tramming? I never bothered since spindle ID (OD wasn't too good but ID was really good below my measuring capability)
    WYLD, that sounds like requirement for 3 phase... eeek. Okay, forget that idea. Maybe tormach is in line if I really need to move up than unless Syil comes up with some other reasonable solution.
    Dec 2006
    118
    hmmm
    I wonder why they haven't offered some additonal belt pully configurations. Seems like a quick easy fix to a problem for a ot of people. I imagine you could even find some aftermarket models that might work.
    You might lose some torque, but additonal rpms would be very nice. have the high speed spindle set up (well i did before it broke) and just another 1700 rpms made a big difference on delrin and aluminum.
    legion
    I don't give a damn if you don't like me, cause i don't like you cause you are not like me.
    Jun 2006
    126
    I do have the high speed option My mill came with just about all options imaginable at the time... (pre syil America).
    I would love to see something like 6000 RPM on this machine as that can roughly reduce my cut time of copper (yes copper... you are lucky talking about derlin I think :P) by 70-80% from what I've been thinking. (especially when using 1/8 or smaller endmills)
    In fact, playing with ME consultant gives me roughly 16000 RPM for optimal RPM for few cuts :P
    I have been thinking few things over anyways (I have MT3 spindle now).
    I would like to move to Tormach tooling (R8 spindle is required obviously)...
    Which means I will have to work on spindle at one point or another anyways...
    which means, might as well change bearing to be able to handle higher speed (of course, question would be the accuracy and rigidity of machine parts too)
    Change the motor (or more likely put VFD drive in there and control it through 2nd parallel port) rework on pulley if required) (2nd parallel port will actually enable me to get something nice like limit switch inputs... heh)
    More I think about, more it will benefit me as long as I can get that higher RPM reliably.
    Dec 2006
    118
    U would probably have to change to high speed bearings as well if you got into those rpms...
    Jun 2006
    126
    Quote Originally Posted by Legion99999 View Post
    Yes, I did think about it of course :P
    The thing I am wondering is, how well made are those R8 Spindles as well as rigiditiy of rest of components.. I would love higher spindle speed with some modification but not at cost of losing accuracy... :P
    Jun 2006
    126
    Guys, I just came around and looked at few things...
    #1. I saw little machineshop has high speed spindle piggy back thing. 100w it says which I presume is about 1/6 hp. I ran some quick numbers on Me consultant and it definitely is in safety margin (0.077 HP for what I want to do..)
    http://www.littlemachineshop.com/pro...2892&category=
    I am wondering if this is much smarter way to go for what I would like to do with high speed.
    #2. My motivation for MT3 to R8 change idea was more than anything due to few unavailable things (or I thought). It seems to me tormach tool changer can be used on MT3 as well?! Kind of defeats the purpose of changing it if such is the case Not that I would mind much at all if I can get something that is turnkey for what I want to do. I can spend the time making more prototypes which is more important
    #3. Anyone have first hand experience with the http://www.littlemachineshop.com/pro...gory=209730719
    automated tool changer. I will be in heaven with this one for sure. I typically will be using 2 drill bits, 3 end mills and possibly one indexible surfacing for what I do. Perfect fit if it can work with SX3...
  1. More Speed needed. Bigger Stepper or increase Ballscrew Pitch ?
    By Joey in forum Stepper Motors / Drives
    Last Post: 11-30-2007, 09:07 PM
  2. How do I increase spindle speed?
    By cnczoner in forum CNC Machine Related Electronics
    Last Post: 07-11-2007, 02:42 PM
  3. Excellent, Speed Increase
    By snoyce in forum DIY CNC Router Table Machines
    Last Post: 04-04-2007, 08:06 PM
  4. Spindle Speed
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 01-28-2007, 05:40 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
