588,692 active members*
7,002 visitors online*
Thread: Hard Drive
Results 1 to 6 of 6
    Jul 2005
    236
    Hard Drive
    I had to replace the hard drive on a H.P. computer that is two years old. For some reason there is no sound since the hard drive was installed. I tried some of the reasons given by H.P. and Microsoft but yet to find out why there is no sound. Everything I have check states that the device is working. Has anyone else ran into this problem and if so what did you do to get the sound working. There is no sound what so every, even the computer sounds are not working.
    Jan 2004
    3154
    Sounds like you didn't reinstall the drivers for the sound chip.
    The drivers will be on your MOBO/manufacturers CD, good chance they will be AC'97 standard.
    www.integratedmechanical.ca
    Jul 2005
    236
    Although I bought the computer new, it did not come with any C.D. I did check the drivers and did a update, but there is still no sound.
    Sep 2003
    72
    I know it a stupid question, but did you plug in the speaker plug into the proper output of your souncard??
    Nov 2006
    89
    Quote Originally Posted by larry53 View Post
    Wiggle and Jiggle is the answer.
    When you had the computer open something was moved and is not making good contact.
    Re-open the computer and then ground youself. (touch and hold a metal part of the case.) With your other hand (while still holding the case) wiggle all the cables to make sure they are connected, wiggle cards to make sure they fully seated etc. Check to make sure that a cable wasn't reconnected.
    Close it up and try again. Make sure all the exterior cables are in the correct location (I've made this mistake myself)
    Check that the speakers have power, are on, and the volume is up. I've made this mistake of unplugging the buggers and wondering why they weren't working.
    It should work.
    Post your results.
    If this doesn't work I give you a procedure to have Windows get it working for you.
    Post the FULL model number. I think I can post a link to where you can get the drivers.
    Jul 2005
    236
    I got the sound to work. Thanks for the replys.
  1. anilam 3300 mk hard drive died
    By nealg in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-19-2010, 06:50 PM
  2. Does anyone backup their CNC's PC hard drive?
    By WayneHill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2010, 03:14 AM
  3. Hard drive servo spindle are any good for home made lathe?
    By patriciooholegu in forum Servo Motors / Drives
    Last Post: 12-08-2007, 04:48 PM
  4. 2x3 THE HARD WAY
    By MrHorsepower in forum Bending, Forging, Extrusion...
    Last Post: 02-01-2007, 06:06 PM
  5. How hard do you have to hit it??
    By zoeper in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2006, 05:07 AM
